Saggy Springs: Add-a-Leaf, Bastard Pack, or other option? - JeepForum.com
post #1 of 6 Old 01-18-2009, 10:19 PM Thread Starter
snaustin09
My rear springs (well all of my springs really) have begun to sag to the point of being basically flat, and invert whenever I am climbing and there is a lot of weight on them. I know that add-a-leaf is a cheap way to restore some arch, but how long does it last and how do they ride? Also, I see a lot of cherokee owners composing their own Bastard Packs, usually using most of their own leaves and some from a donor S-10 or other dodge pickup, however, I could not find any YJ owners doing this. Has anyone else had any experience with this? Can I make a bastard pack just like a Cherokee? Also, are there any other options to this problem, preferably relatively cheap? (I'm on a student budget) I know I can get them re-arched, but it seems like this would just further fatigue the metal and will end up right back where it was. Any advice, help, experiences, and especially pictures are greatly appreciated!!
"If the ladies don't find you handsome, they should at least find you handy" -Red Green
snaustin09 is offline
post #2 of 6 Old 01-18-2009, 10:24 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
On stock size tires?
If so, I bought brand new, stock height springs from Q-tec for $79 each.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 6 Old 01-18-2009, 10:29 PM Thread Starter
snaustin09
Yea, just stock 29" tires. I was hoping to find someone who had replaced their springs when they installed a lift and buy their original stock springs for cheap. I don't wheel much, just want something that isn't so warn out, and a little more lift is never a bad thing. Any other options, though?
post #4 of 6 Old 01-28-2009, 12:04 AM
Cherokee2
1990 XJ Cherokee
I have a similar question. I have a 90 cherokee and was looking around for a cheap 2" lift. I was looking at the Rubicon express add-a leaf kit, but I believe my rear leafs are sagging a bit, and I would think the add-a leaf wouldn't do much. I'd rather get some donor leafs from a newer car. Does anyone know of any for ones that would give me around the 2" of lift for a cherokee. Fron springs?
My plan is to run to a pick n pull and (hopefully) for a ~$100 or so I could get myself a newer suspention thats about 2" higher. Anyone know of a donor car I can use?
snaustin09 - I would just run to your local junk / parts yard and grab some stock leaf springs. My local Pick n Pull charges me 2 bucks to run around their yard, and parts are fairly reasonable. I wouldn't think a used pair would run you very much - and as long as you got some jack-stands and some basic tools, you'd probably be fine.
As far as the re-work, I would seriously avoid that. In my opinion that would be more of a hassle, and yeah - metal fatigue is not worth the chance of your axle falling off at highway speed.
Cherokee2 is offline
post #5 of 6 Old 01-29-2009, 04:45 PM Thread Starter
snaustin09
I would gladly do this, but my local junkyard, for some reason, never has any wrangler, despite a plethora of Cherokees (at least I can get engine parts). Has anyone ever composed a bastard pack for a YJ? If so, from what donor springs?
Thanks
post #6 of 6 Old 01-29-2009, 05:30 PM
Btwngreengray
I went on a MOPAR site and ordered some brand new ones. Cost me under $180 for both.
"If ye love wealth better than liberty, the tranquility of servitude than the animated contest of freedom, go from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains sit lightly upon you, and may posterity forget that you were ever our countrymen! Samuel Adams.
Christian Jeep Club Member #104
Btwngreengray is offline
S10 bastard pack installed in a YJ Uberjeep YJ Wrangler Technical Forum 18 12-18-2009 09:21 PM
Bastard Pack. WalrusPaul YJ Wrangler Technical Forum 0 08-10-2009 03:58 AM
Saggy rear leaf springs 1C41N0 YJ Wrangler Technical Forum 1 04-02-2009 05:54 AM
bastard pack? will_982 YJ Wrangler Technical Forum 6 04-02-2008 07:19 AM
5 leaf pack front, 6 leaf pack rear???? UCF YJ'r YJ Wrangler Technical Forum 12 01-28-2007 07:56 AM
