Saggy butt. AALs or flip the shackles? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Saggy butt. AALs or flip the shackles?
RCI FUEL CELL BRACKET - Perfect for the back of your JeepULTIMATE Dana 60 High Steer Arms!!!JK Front Axle Truss
Unread 12-30-2010, 11:17 AM   #1
-Deepskyy-
OK so I have an OME 2.5 lift and inch and a quarter daystar shackles on my YJ. Lift has been on for just over a year and I LOVE IT! Super flexy and no rub issues even at max flex. The only issue is the butt sag. I still have a set of AALs from my stock spring packs, so I'm contemplating adding them to the OMEs in the back. Is this going to actually help out or should I flip the shackles in the back?
For those who haven't seen Daystar shackles, here.
Right now the long side of the shackle is on the frame. I figure if I flip them it should push the frame higher and fix the sag.
Thoughts? Any other way to fix a saggy butt?
Are you finding the Jeep Forum helpful? Donate today!
"I never saw such fighting since God made me. The Americans fought like demons"
-Lt. General Charles, Earl Cornwallis after the battle of Guilford Courthouse NC
Originally Posted by Outatime05 View Post
Females are a dime-a-dozen. Jeeps are forever. Easy choice. Be indispensible or be gone. :wave:
Originally Posted by jeepdavetj View Post
We are Jeepforum. We can do the unthinkable. We are Jeep strong. And head stubborn. We are. JEEPFORUM.
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Red Jeep #543
-Deepskyy- is offline   Reply With Quote
Unread 12-30-2010, 11:22 AM   #2
Joe Dillard
Electric Chair Operator
Flipping the shackles will not make them any longer - therefore, you will not get any additional lift from them.
If you think about it - the shackles aren't getting any longer (bolt hole to bolt hole) so doing a simple flip won't gain you any lift whatsoever.
Joe Dillard is offline   Reply With Quote
Unread 12-30-2010, 11:23 AM   #3
xaran
I cant see how flipping the shackle will make any difference. The conection ponts are spacing the leaf the same distance from the frame either way.
I had AAL on my stock suspension and they were not very good, really harsh ride
xaran is offline   Reply With Quote
Unread 12-30-2010, 11:33 AM   #4
-Deepskyy-
Argh... I let my inner idiot out with that one. Of course the shackles aren't longer one one side than the other. Duh.
My old AALs really didn't cause me any greif, but then again my shocks were shot so I wouldn't have known the diffrence. My problem is I broke on when I got hung up on a rock.
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Red Jeep #543
Unread 12-30-2010, 11:42 AM   #5
jbeebe
yea x100000, flipping shackles won't do anything. don't do an AAL either. if your OME spring packs are sagging, won't their warranty cover it?
jbeebe is offline   Reply With Quote
Unread 12-30-2010, 11:46 AM   #6
MLJeeper
You'll get way more lift from a good set of BDS or Rubicon Express stickers.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline   Reply With Quote
Unread 12-30-2010, 11:47 AM   #7
-Deepskyy-
They aren't sagging per se, its just the natural effect of the heavy tub making the rear lower than the front.
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Red Jeep #543
Unread 12-30-2010, 11:59 AM   #8
UltimatE
Resident Audio Guru
UltimatE's Avatar
Did you get medium or heavy duty springs for the rear? YJ's benefit from heavy duty springs all around, especially with heavy bumpers, armor, etc. The fronts are almost always heavy duty, because that's where more of the weight is.
-Matt
White '94 YJ Sport
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar
Project (s)Low - A build log.
UltimatE is offline   Reply With Quote
Unread 12-30-2010, 02:18 PM   #9
-Deepskyy-
HDs all the way around.
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Red Jeep #543
Unread 12-30-2010, 02:56 PM   #10
SnowdogMarc
I had the same issue with mine and swapping the 8.8 in just magnified it. I just fabricated some longer boomerang shackles for the back to level it out.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline   Reply With Quote
Unread 12-30-2010, 04:22 PM   #11
-Deepskyy-
I might talk to the guys at 4wheel parts to see what I can do about getting the rears replaced. The only thing I don't look forward to is installing another set of springs. Parking lot at my apartment can be a PITA to work on things.
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Red Jeep #543
Unread 12-30-2010, 06:14 PM   #12
Noltz
Heavy duty 2" longer shackles will bring up the tail end by 1". Upgrade & fix in one.
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4½" & shackles, BFG 33's (sold)
Noltz is offline   Reply With Quote
