Is this safe for a stock jeep - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Is this safe for a stock jeep
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !
Unread 08-21-2006, 11:10 AM   #1
SteveS
I just installed 15x10 rims with 3.5 back space. Tires are 31x12.5x15 BF Goodrich. Tires stick out about 7 inches past the stock flairs. I can replace the flairs. But changing the width of the stock jeep will this be safe on stock axles and studs?
SteveS is offline   Reply With Quote
Unread 08-21-2006, 11:16 AM   #2
tcourdin
It should be just fine.
88 Wrangler, Rebuilt I6, NV3550,Atlas 2,B&M Shifter,38/38 Weber, Skyjacker Lift & Nitro Shocks & Stabilizer, Black Diamond Discos, 35 " Regul MT's & Outlaw 2 Alum Wheels, 4.88 Gears, Dana 35 & Super 35 kit & Detroit Soft Locker, Dana 30 & Superior Axles & Detroit Soft Locker & No Disco, SRC Front & Rear Bumpers, SRC Side Armor, Warn XD 9000 I Winch & In Cab Controls, OR Fab Tire & Can Carrier, Rock Hard 4x4 Full Cage, Hood Rack & Hi Lift & AX, Outland Seats, KC & Silverstar.
tcourdin is offline   Reply With Quote
Unread 08-21-2006, 11:45 AM   #3
RIGSBN8R
There will be added stress on your hubs, but it will take some time before you notice any signs. 'Sides, then you'll have a reason to upgrade.
[url]www.georgiajeeps.com[/url]
RIGSBN8R is offline   Reply With Quote
Unread 08-21-2006, 01:35 PM   #4
Ares
Shouldn't hurt anything initially. Over time, you'll notice excessive wear. If your really concerned and are running D30s or something, you can always upgrade a little to D35s or an 8.8.
- Cameron
Axle Information Thread
Oil Filter Study
Ares is offline   Reply With Quote
Unread 08-21-2006, 01:47 PM   #5
GrimJeeper91
31x12.50??? Sure they are not 31x10.50? 31x10.50's would look gay on 10" wheels unless you have a chain steering wheel, chee chee balls and a velvet dash.
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline   Reply With Quote
Unread 08-21-2006, 03:17 PM   #6
SteveS
Yes these are BF Goodrich KO 31x12.5x15 BF Goodrich recommends 9 to 11 inch width rim.
Unread 08-21-2006, 03:22 PM   #7
biggreentj
u will be just fine!
[B]91 YJ 4.0/ax15 Stretch to 102" D44s 5.38s Detroits/Hi Steer/38.5"TSLs/Custom full cage/ Corbeau seats/Crow Harnesses/PSC comp corners.[/B]
biggreentj is offline   Reply With Quote
Unread 08-21-2006, 03:29 PM   #8
GrimJeeper91
I've never seen this size in a BFG. I double checked their web site and the AT KO is not available in a 31x12.50x15. Maybe you need thicker glasses.
http://www.bfgoodrichtires.com/asset...rain_ta_kd.pdf
Unread 08-21-2006, 03:51 PM   #9
z71offroader
i also have never hear of a 31x12.5 even if it is 12.5" wide id rather have a 8" wide wheel.
93 YJ- SOA, R.E 1.5" Leafs, Custom paint, 35x16 Boggers,15x10 97 series rockcrawlers. Diamond plated interior and exterior, Tera SYE/CV DS, Herculined Tub, Bestop, Warn Bumpers w/ 9.5ti, 8.8" rear, D30 front, both ARB's with 4:88's, Super 88, Posi-Lok, Alpine Stereo, Tuffy Security, Hella Fogs, ProComp Spots, and much more.
07 2500HD D-Max CC LB Black Ranchhand Bumpers, MBRP 5" Straight Piped Exhaust, Edge Evo, N-fabs, 305/65/18 BFGs on Black Motos, much more soon to come!
(Sold)03 Z71- 33x12 BFG Muds, American Racing Victor Teflons, K&N intake, Gibson Exhaust, Ranchand bumpers, Hypertech programmed, Hella Spots, 12" JL sub, and much more.
z71offroader is offline   Reply With Quote
Unread 08-21-2006, 04:37 PM   #10
SteveS
Thanks everyone! I bought the tires used. I dont think BFG makes them anymore. Anyways I might sell the wheels and get 15x8 and keep the tires. I got a great deal.
Unread 08-21-2006, 05:39 PM   #11
Ares
They're out there. Do a google search for that size and you'll see quite a few people talking about them. Granted they are very uncommon
http://www.oasis4x4.com/neumaticos1.htm
Towards the bottom of the page the Xtarrain is that size for example
- Cameron
Oil Filter Study
Unread 08-21-2006, 05:40 PM   #12
COSourdough
Um...the D30 is the stock front axle, D35 is the stock rear, and not at all an upgrade from the D30...The 30 is stronger than the 35. Upgrades would start at a D44, then 8.8, etc...
COSourdough is offline   Reply With Quote
Unread 08-21-2006, 05:49 PM   #13
z71offroader
they must not make them anymore then like u said. BFG does make that size currently in the mud terrain tho. procomp also makes that size for there all terrain, mud and xterrains, along with superswamper boggers, thornbirds and radial ssr's. but imo 12.5" is to wide for a 31" tall tire, makes them look to fat and stocky, a 11.5 or 10.5 is more proportional imo.
Unread 08-21-2006, 06:23 PM   #14
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
wide tires look awesome.... what are yall smokin
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS!
Big-n-Broke-YJ is offline   Reply With Quote
Unread 08-21-2006, 06:40 PM   #15
flame0086
I was going to say the same thing...
flame0086 is offline   Reply With Quote
