Safe Oil Pressure? - JeepForum.com
post #1 of 3 Old 06-18-2013, 01:53 PM Thread Starter
TA-YJ
Safe Oil Pressure?
I fired up the "new" engine the other day and the oil pressure has caught my eye. My old engine would go from ~20psi at hot idle to ~60psi on the highway. The one I dropped in goes from ~15psi (Maybe a little lower) to ~45psi on the highway. I swapped the pressure sensor over so I know that is not the issue. I am just wondering if these pressures are safe. Thanks.
1992 YJ 2.5L
Engine Mods:4.0L TB, Ford Design III 19lb Injectors, Firepower Ignition System, Ford TBird Electric Fan, Pacesetter Header, Magnaflow Cat, Dynomax Super Turbo Exhaust
Suspension Mods:BDS 2" Lift, M.O.R.E. 5/8" HD Shackles, 1" Brown Dog MML
Other:LED Tails and Herculined
TA-YJ is offline
post #2 of 3 Old 06-18-2013, 01:57 PM
jokerchief462
Yes you are good. IIRC the book says 40-75 at high RPMs and 15-40 at idle. Each engine acts differently depending on age and the oil and the temp. Enjoy the engine it should last a long time with care.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 3 Old 06-18-2013, 02:04 PM
dillonjm
2013 WK
Typically 13-15 @ idle then 10psi/1000rpm is min spec (as read from a mechanical gauge).
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
