S10 blazer tire carrier on YJ....DONE! - JeepForum.com
post #1 of 49 Old 05-02-2012, 04:59 PM Thread Starter
ashland82391
Hey, before I did this mod I looked and looked and i couldnt find anything on putting a blazer tire carrier on a YJ or TJ, so I had to go into it blind. Here is some information for thoughs that my be interested in doing the same thing.
Benifits
-cheap
-custom
-strong
-saves tail gate
Cons
-labor intesive (at least for me)
-not as strong as 500$ smitty built
Tools
-grinder!!!
-welder
-drill w/ good drill bits
-pipe to bend metal with
-vise
-normal hand tools
Things that have to modified
-blazer tire carrier hinges
-blazer tire carrier latch catch
-build support brackets
Ok, so first, expenses. I got the tire carrier for 20$ at junk yard, 10$ for grade 8 bolts(I wouldn't get anything less), and I had some scrap metal laying around for the support brackets so it was free for me, but shouldn't cost any more than 10-15$.
The first thing I did with the tire carrier was modify the hinges. the top one I cut in half and gave it more of a bend to match the YJ corner(hinges are cast steel so kind of a pain to weld) and the bottom one I just cut off right between the second and last bolt hole because the bottom hinge not cut will interfere with the fender flare.
The next thing I had to do is grind the hinges flat because the body couture of the blazer is curved and obviously the YJ is flat. This part was pretty time consuming.
582724_10151689790650425_690405424_23667407_620333123_n.jpg   523043_404612239570538_100000652962741_1378433_1295868789_n.jpg   543377_404607029571059_100000652962741_1378418_740626217_n.jpg
ashland82391 is offline
post #2 of 49 Old 05-02-2012, 05:02 PM Thread Starter
ashland82391
Next I had to cut the latch catch from the mounting plate and extend it. I did 4 inches but I recommend 3 inches. I will be shortening mine down when I get the chance. As you can see in the second picture I cut down one of the stock YJ tire bump stops and slid it into the center of the latch catch so that it didn't rattle. If you don't do something like this it will rattle.
538366_404582539573508_100000652962741_1378382_1713711959_n.jpg   100_2081 (800x600).jpg
post #3 of 49 Old 05-02-2012, 05:11 PM Thread Starter
ashland82391
I then had to build support brackets so that the tire carrier doesn't rip off and trust me you'll need them. From just the weight of the tire carrier it looked like it was going to rip off the side of the jeep. I don't have any exact measurement on hand but here are some pictures of the brackets I built.
546550_404603666238062_100000652962741_1378410_614102542_n.jpg   540054_404598632905232_100000652962741_1378399_757262938_n.jpg   100_2080 (800x600).jpg   582681_404594536238975_100000652962741_1378394_1748765612_n.jpg   578584_404590819572680_100000652962741_1378391_1611934198_n.jpg
post #4 of 49 Old 05-02-2012, 05:15 PM Thread Starter
ashland82391
And that's basically it. Im very happy with it and its super strong. Please feel free to ask questions. Here's some more pictures of the finished product.
The one of me sitting on it, I'm 145 lbs and the tire is about 35 so 180 lbs and it didn't budge.
100_2091 (640x480).jpg   100_2078 (800x600).jpg   100_2077 (800x600).jpg   100_2088 (640x480).jpg
post #5 of 49 Old 05-02-2012, 05:46 PM
superj
thats a hell of a good job!!! it looks factory and your inner metal looks great too. you should make spares and sell them
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #6 of 49 Old 05-02-2012, 06:20 PM Thread Starter
ashland82391
Thanks a lot man! That would be a good way to make me some more jeep money!
post #7 of 49 Old 05-02-2012, 06:31 PM
jbolty
jbolty's Avatar
Looks great. One change I might make though is to attach the latch to the tub, rather than the tailgate.
"The right to be heard does not necessarily include the right to be taken seriously." óHubert Humphrey
jbolty is offline
post #8 of 49 Old 05-02-2012, 06:35 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Your hard work paid off. Good job!!
Luck Favours The Prepared
Anticanman is offline
post #9 of 49 Old 05-02-2012, 06:39 PM Thread Starter
ashland82391
I would have liked to do that, but I would have had to extend the entire tire carrier and relocate the tire bracket to the center of the carrier.
post #10 of 49 Old 05-02-2012, 06:40 PM Thread Starter
ashland82391
thanks!!!
post #11 of 49 Old 05-02-2012, 06:53 PM
'92 vegas YJ
great job.
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
'92 vegas YJ is offline
post #12 of 49 Old 05-02-2012, 07:36 PM
MaddBones702
way to go!!
Who knew where this would go?
MaddBones702 is offline
post #13 of 49 Old 05-03-2012, 04:25 PM
AmmitOsiris
what size tire is the biggest you can fit on there and hold strongly
AmmitOsiris is offline
post #14 of 49 Old 05-03-2012, 05:02 PM Thread Starter
ashland82391
Im sure it will hold a 35 no problem because the picture of me sitting on it with the tire is aroud 180 pounds and it doesnt budge and thats with it open. So with it closed im sure it will hold over 200 pounds.
post #15 of 49 Old 05-12-2012, 05:48 PM
linusb
I was at junkyard today and almost snagged tire carrier from a 99 blazer. I don't yet weld but think this could be good project to cut my teeth on.
What was your technique for bending the metal for the corner brace? Is there also a brace on bottom hinge?
What size steel did you build the brace out of?
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
Will OR-Fab Tire Carrier Cover Bestop Tire Carrier Holes? IH8ROADZ TJ Wrangler Technical Forum 1 02-07-2012 02:02 PM
arb rear bumper w/ tire carrier vs currie rockcrawler2 w/tire carrier and rockribs lstcj7 Wrangler General Discussion 0 07-03-2010 07:57 AM
Will a broncoII/blazer swing work? (tire carrier) MuddyLugs TJ Wrangler Technical Forum 4 03-17-2009 07:01 AM
Bestop Tire Carrier or Bumper/Tire Carrier Combo dallasjetfan TJ Wrangler Technical Forum 6 12-22-2008 09:46 AM
Anybody ever use a 2 door blazer tire carrier on a wrangler? slater03 TJ Wrangler Technical Forum 0 03-01-2007 05:19 PM
