Okay so here is a thread of the rear axle project/fab things I've been working on. http://www.jeepforum.com/forum/f37/yj-coil-conversion-1234448/ Well my question is on the sye. Check page two of my thread if you want pics of it..After the install, i tryed hand turning the rear yoke and it spins smoothly until it's last 10% or so of rotation, then it becomes "stiff" but continues to cycle and frees up once completed. Is this because it's in 4lo? Bad install? I'm stumped and don't really want to take the tcase apart again until someone has some insight. Thanks, Eric.
I haven't tried those two yet but I will here in a second. I'm really stumped because it was really a snap to put in, I followed all of the steps. Prelubed parts and torqued everything to spec. Also, got the oil pump hooked up correctly so who knows..I'll report back in a second.
Well I just took the tail housing off then spun the shaft and no binding at all smooth as butter! Then I decided not to crack the case halves and button it back up with a fresh bead of rtv. As soon as I got the 5 bolts snugged down, binding just like before! Son of a BIT@&!! What's the deal here?
Now wait...Hmm. I slightly remember a problem like this when I was working in my uncles transmission shop one day. I was only there for a few days doing a carreer study for school, I'm trying to remember what the problem was though. It was on a dodge ram 2500, I'm fairly sure it was the transfercase oil pump, I could be wrong though. You already elimnated the pump though as the problem...maybe your looking at the wrong end of the issue, maybe it's the diff thats the problem and has been a problem with your original drive shaft just you didnt spin the original by hand to realize you had a problem. Just a thought.
I never did twist it with the old slip yoke drive shaft..hmmm. I think I might just take it to a guy in my club who owns a jeep shop. Linkage is correct, supposed to be like 9.30" I think is what the manual said? Ugh this is preventing me from working on more important things..
Okay, a real update. I could not get my transfer case worked on in a reasonable time frame so I split the case again and took pictures of how it is assem. Does everything look okay?
Hmmm. Everything looks alright but I didnt take that close of a look, I dont have much time, I need to run to the auto parts store. But did you try spinning the rear and see how that is? I've got a feeling your looking at the wrong end of the problem. And like 1SASjeepster said, call the manufacter, they could help you trouble shoot the problem and give you ideas where to look that we havent thought of yet.
Okay called the company.All they said was to check torque specs to make sure everything is aligned properly. Did that and took 3 videos to see what I'm talking about. Here you go, make sure you watch all 3
Yeah I tried that out. I have a club meeting tomorrow night and I'm dropping it off to a guy that owns a shop. Hopefully he can solve my issues
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
