Rythmic tapping sound. - JeepForum.com
post #1 of 8 Old 07-23-2013, 09:51 AM Thread Starter
HKusp
I have a recently acquired 1993 4.0 liter YJ with a 4 inch lift and 33x12.50's. It has approximately 210K miles (actual is unknown as the speedo/odo apparently haven't worked since it had 115K). We just took it on vacation with us to Chincoteague, Va. (About 175 miles one way). I wasn't driving it as I was hauling the travel trailer, but the wife said it drove fine except for a tapping noise she was hearing. I thought it was probably a noisy timing chain she was describing and didn't think anything of it until I drove it.
I am definitely hearing a metallic tapping sound coming from underneath that sounds more like it is coming from the passenger side middle of the tub area. It is regular and changes speed with the speed of the vehicle, pushing in the clutch has no effect at all. I haven't messed with the transfer case yet because I don't want to start any issues with getting it stuck in 4wheel drive at least until I get it home. It sounds almost like maybe some slack in a u-joint maybe to me, at least that is what jumped in my somewhat limited mind anyway. Now we just replaced the passenger side u-joint on the front wheel a few weeks ago as well as the long steering arm that I would describe as the tie rod end except it is about 3 feet long, but I don't know what it is really called, (this is my first actual jeep so bear with me guys, I am trying to get up to speed )I also just put a used exhaust from the cat back including a Dynomax muffler and tailpipe on it right before the trip, but I used new exhaust clamps and isolators and it doesn't sound like the exhaust banging at all.
I was speaking with a mechanic with 20+ years experience, that was camping behind me and he is a Jeep guy and said most likely it was the transfer case chain. He said that was fairly common and not a big issue until we were doing some decent wheeling. I didn't get a chance to take him for a ride before he left to get a "confirmation" of that.
I realize it is very hard to diagnose these things over the internet, but is that at least probable? I have driven it maybe 50 miles around the island over the last week and other than the noise, it is running great. The steering is tight and feels good. I ask, because the wife and kids are still down the beach, I needed to come home and work for a few days. I am hoping to avoid it being an issue on the ride back this weekend.
Sorry for the long post but I want to get an action plan together if need be. Thank you guys, for any and all input.
HKusp is offline
post #2 of 8 Old 07-23-2013, 08:34 PM Thread Starter
HKusp
So no one even looked at this....?
HKusp is offline
post #3 of 8 Old 07-23-2013, 08:55 PM
Why J?
Why J?'s Avatar
Chains tend to make noise in 4wd only.
Loft the rear end, tires off the ground supported with jack stands and run it. Climb underneath.
Could be lifters chattering.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #4 of 8 Old 07-23-2013, 10:13 PM
bigbossd1030
That would be a drag link.
Now this noise, okay, so we know it happens when the jeeps speed changes, does it make the noise while it is parked and running? Does it change with the rpms? Any heat shields loose? Crawl under and give the drive shafts a good shake. See if there is any play. Any time I have had a ujoint take a crap there is normally a vibration in my experience. I would do what whyj said. It sounds like it is coming from somewhere in the driveline. Time to eliminate where in the driveline. Front or back, left or right. Driveshaft or axle. Crawl under and start shaking stuff to see if anything wiggles around.
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #5 of 8 Old 07-23-2013, 10:13 PM
Reno72
If I understand you, it only makes this sound while moving? If that's the case it would seem to narrow it to driveline and not motor.
Reno72 is offline
post #6 of 8 Old 07-24-2013, 08:02 AM Thread Starter
HKusp
Yes, it only makes the sound when moving. If the clutch is engaged or not, and I definitely don't think it is the lifters. I will jack it up and go from there. I will report back what I find. Thank you for the suggestions.
HKusp is offline
post #7 of 8 Old 07-24-2013, 08:13 AM
Siva283
Sounds like a U-Joint to me. Time to get to shaking. They dont always cause vibs though well not until they get really bad anyway.
Ask me how I know...
Siva283 is offline
post #8 of 8 Old 08-12-2013, 01:26 PM Thread Starter
HKusp
Sorry it has taken so long to give an update on the tapping sound. It turns out it was multiple sources. Number one was the rear universal joint on the front drive shaft and number 2, and this is the big one, was the bearing on the front of the transfer case. Pricing out the R&R of it looks to be more expensive than replacing with a used unit so I think we are just going that way. I am looking at a unit from a 2001 4.0 that comes with an SYE already installed and it comes with a set of drive shafts already set up for a 4 inch lift. The guy wants $500 so I hope to go that route. Thanks for all the ideas on how to diagnose.
HKusp is offline
