rust spots - JeepForum.com
post #1 of 7 Old 10-09-2012, 08:16 PM Thread Starter
mchumsae
rust spots
So I have a 95 yj with some rust spots that are not all the way through from what I can tell, and in addition to this there is some mild rust on the hinges on the front doors. How can I repair this?
Thanks!
mchumsae is offline
post #2 of 7 Old 10-09-2012, 08:33 PM
90DesertTanYJ
I use a Rustoloeum product that neutralizes the rust and leaves a paintable surface. Cant remember the name but it goes on milky and turns black and hard after it dries. The surface can be filled with spot putty to smooth it out. Body shop protocol would be to grind away all the rust then paint and spot putty/bondo. I figure I wont be entering any car shows so I take the easy route. Stop the rust and dont worry about it.
90DesertTanYJ is offline
post #3 of 7 Old 10-09-2012, 08:51 PM
rodgers3
Rustoleum rust reformer.
I use the stuff its great!
rodgers3 is offline
post #4 of 7 Old 10-09-2012, 08:56 PM Thread Starter
mchumsae
Thank you guys! will buy some first thing tomorrow!
mchumsae is offline
post #5 of 7 Old 10-10-2012, 01:08 AM
kjg26
kjg26's Avatar
They sell that in rattle can form?
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #6 of 7 Old 10-10-2012, 07:47 AM
89WhyJ
Yeah.
I use basically the same thing from Dupli-Color: Rust Fix. Sprays on clear, and turns only the rust to black primer. I've used almost a full can of it. The stuff is great!
89WhyJ is offline
post #7 of 7 Old 10-10-2012, 09:44 AM
rodgers3
They do but personal experience the brush on works better than the rattle.
If u plan on topcoating it the rattle can works just fine
But if you don't plan on top coating it because you like the flat black.
Use the brush on.
rodgers3 is offline
repair , rust , YJ
