10-02-2004, 01:32 PM
#1
This could be my imagination but it sems that since I have stopped using my Jeep has a DD that everything inside the engine bay is rusting in hyper drive.  The block has rust all over, new parts that i have installed this summer are starting to rust even the aluminum pieces have some kind of fuzzies on it.  I'm really agravated is there a way of slowing the rust down? Is there some kind of chemical that's causing this? Also what about this gadget in JCWhitney that's supposed to energize the metal to stop rust, is anyone using this?
95 4L Auto D300 TC
103" Wheelbase
D60 Front 14 Bolt Rear 4.10 Gears
H1 Wheels 36" GoodYear OZ Tires
10-02-2004, 04:48 PM
#2
spray everything down with WD-40
SoCal Jeep Club Member #11
10-02-2004, 04:56 PM
#3
wouldn't that be dangerous inside the engine bay once the motor got hot?
95 4L Auto D300 TC
103" Wheelbase
10-02-2004, 06:25 PM
#4
WD-40 will work for a short time and burn off the engine.
The best thing to do is get some aersol rust convertor and spray the rusting parts. It turns to a dull black. I spray paint my undercarriage every couple of years with flat black rust preventitive paint to keep it looking good.
10-02-2004, 07:53 PM
#5
The reason I mentioned WD-40 is because:
When I used to have PWCs and used them in the ocean, it was advised that after flushing the motor and washing down the engine bay and everything, that you "fog" the engine compartment with WD-40. After a good two years of ocean use, my boats looked like new.
10-02-2004, 07:54 PM
#6
Also, when I clean my toybox, after I put it away I spray WD-40 all over the cheap chrome wheels and just leave it on there. Sure they get all dusty dirty, but they clean right up when Im ready to go again and theres no rust...
10-02-2004, 10:56 PM
#7
H2 Recovery Team Member
no need to worry about the aluminum parts. once the surface oxidizes it will stop corroding. ever see a rusty beer can? lol. like xxx said, get some kind of coating and spray down the rusting spots. if you want to do it right, wire brush the rust spots, degrease, and then paint with engine enamel in the color of your choice. this stuff is good for elevated temps but don't try it on the exhaust parts. for them, you can get high temps stuff like POR-15's header enamel or some sort of industrial coating rated for the elevated temps.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
10-03-2004, 05:28 AM
#8
Well i'll try it sounds easy enough. Thanks
95 4L Auto D300 TC
103" Wheelbase
10-03-2004, 07:34 AM
#9
Ya, you know how cheap the chrome is on those wheels... As soon as these tires justify replacement, Im going to put no the black Soft 8s to match the Jeep
Ya think I could put some BFG ATs on my toybox?  ~kidding
10-03-2004, 08:40 AM
#10
Sounds like you need to start driving it everyday.
USMC 2006-Present
Sold: 2000 TJ - D44/D30 with 4.88s, Advance Adapters SYE, Tom Woods CV, Vanco Big Brake kit, 35x12.50 BFG KM2s, ProComp Series 51s, Rough Country 4" Series II, Bilstein 5100 Shocks, Currie HD Steering, Rokmen Adjustable Control Arms, ProComp Adjustable Trackbar, Currie Anti-Rock, MetalCloak Front Bumper and Stinger, Warn rear bumper/tire carrier
10-03-2004, 12:38 PM
#11
POR 15 works great too.... only bad thing is if it gets on you, it doesn't come off for a month or two.
1994 Jeep Wrangler 2.5L (White)
10-03-2004, 06:06 PM
#12
Man you have no idea how much I want to drive it everyday. Instead of the jeep I get to drive a friggin dodge neon. I have no choice but to swallow my pride since the neon saves me about $80 a week in gas.
95 4L Auto D300 TC
103" Wheelbase
10-03-2004, 07:44 PM
#13
so compromise and drive it two days a week and only save $60 a week after filling up the jeep once. lifes too short not to drive a jeep at least one day out of the week
