Rust hole through body-how to fix?? - JeepForum.com
post #1 of 18 Old 02-27-2004, 12:30 PM Thread Starter
JEEPINWI
Hey Guys~
I have had some rust spots surface over the past couple years, but one has finally gone all the way through the body. I will post a picture by tomorrow. It is on the driver's side rocker panel and about 2" around. What would be the best method of fixing this problem and keeping it from returning? I have already ordered some Por-15, but what else should I use to fix/fill this permanantly? Any links for info on repairing rust would also be appreciated. Thanks.
Brian-
99 XJ Cherokee, 2 door, 4.6L Stroker, 5 speed, 4x4, 8.25" rear, 3.07 gears
JEEPINWI is offline
post #2 of 18 Old 02-27-2004, 03:24 PM
xxxflhrci
xxxflhrci's Avatar
Do you want to fix it or stop the rust and hide the area?
Fixing back to look original it is gonna cost some bucks. You will have to cut out the spot and patch it, then have the whole panel painted.
Hiding it is the best option. Cut and grind out all the rust, then POR 15 it. Then the fastest hiding job is to bolt on some diamond plate rockers. Another option it to Bondo or Fiberglass up the whole and paint your rockers with something textured like Heruliner to hide you patch.
xxxflhrci is offline
post #3 of 18 Old 02-27-2004, 03:43 PM
saint152
saint152's Avatar
Originally Posted by JEEPINWI
Hey Guys~
If you are not a welder and cant use sheet metal.....just grind or cut out the bad spots (make sure you get all of it or it will come back) then put some fiberglass cloth behind the area you cut out. Once the fiberglass dries....you can bondo on top of that to smoothe the area out.
If you have never tried this before and are intimidated about doing so.....DONT BE! It is REALLY EASY!
1990 YJ, 258 w/ weber carb, HEI upgrade, 3.5" springs, 2" body lift, 1.5" shackles, TJ flares, Eagle 118 15x10" wheels, Rocker guards, 35x12.50x15 GY MT/R's, Lockrite F/R, POSI-LOCK, Dual Batteries (optima Red/Optima Yellow) Bestop Super Seats, 9000lb Superwinch, Custom bumpers w/ swingout tire carrier, and Rockford Fosgate for my listening pleasure!
saint152 is offline
post #4 of 18 Old 02-27-2004, 11:58 PM
fratis
fratis's Avatar
welding
i had alot of leftover holes in my floorboards from the original owner. i welded them up and it worked great. id suggest cutting out the bad metal. id be agressive and cut out at least an inch into what appears to be good metal. id then weld in a piece of sheetmetal. if you dont have a welding machine you probably could rent one. homedepot has a decent manual on welding with some good info. if you use bondo make sure to prime the metal first. when bondo is setting it can get condensation inbetween it and metal. best to stay away from bondo though, has a habit of cracking while offroading
fratis is offline
post #5 of 18 Old 02-28-2004, 12:03 AM
saint152
saint152's Avatar
Use Evercote Polyester Body Filler..........it is 1000 times easier to sand than Bondo and will never crack!
saint152 is offline
post #6 of 18 Old 02-28-2004, 12:19 AM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
if you do want to go the welding route and depending on where and how bad the rust is, you might want to get replacement panels from quadratec. they have preformed weld-in replacement for just about the entire interior. they're all under 50 bucks and might save you some aggravation.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #7 of 18 Old 02-28-2004, 04:46 AM
GEAH
GEAH's Avatar
1974 CJ5
Save your money and patch it
74 CJ5
304CI
3spd
GEAH is offline
post #8 of 18 Old 02-29-2004, 12:00 AM
rrclimber
rrclimber's Avatar
Here is a link to a guy that did some work with the bondo. Looks pretty straight forward.
http://www.jeepz.com/modules.php?op=...=body_bodywork
Merry Wacko Jeep Club Member #William Shatner
95', 4.0, 4" Rusty Lift, 33" Pro Comp AT's, Quick Release II Mirror, Pavement ends flip-top, Alpine deck, bazooka amp, sony 10" sub.
rrclimber is offline
post #9 of 18 Old 02-29-2004, 09:01 AM Thread Starter
JEEPINWI
Here's a link to the page where I have a pic posted. Jeep Rust . It's not actually a pic of my Jeep, but exact same rust spot. Scroll down a bit and it's pic #11
I have access to all the equipment to permanantly repair the rust, but never had to fill in any holes. I like the idea of using the fiberglass patch then going over it with the Evercote Polyester Body Filler. I am a little intimidated by the welding as this spot is quite noticeable and although I am a decent welder, I don't feel I could get a smooth finish.
Brian-
JEEPINWI is offline
post #10 of 18 Old 03-05-2012, 10:12 PM
idskot
Would the 'Lite Weight' do, or the 'Kitty Hair' one?
idskot is offline
post #11 of 18 Old 03-05-2012, 10:23 PM
Apollo12227
Dusted the cobwebs off this thread I see... Necrothreadillia is the term I believe I heard for just this occasion. Kidding aside I'm sure someone will get around to your question.
Apollo12227 is offline
post #12 of 18 Old 03-06-2012, 09:30 AM
idskot
OH! Wow. I didn't even bother checking the year, thought it was last posted 2 days ago!
idskot is offline
post #13 of 18 Old 03-06-2012, 09:44 AM
MegaCabMan
I know, old thread. but here is my 0.02 anyway...
Bondo is for show cars, not trail rigs and DD jeeps.
They call me the King of Fun! Everwhere I go I hear "Here comes that Fun King MegaCabMan"
MegaCabMan is offline
post #14 of 18 Old 03-06-2012, 10:12 AM
idskot
How do you suggest I fix a bubbling rust spot?
idskot is offline
post #15 of 18 Old 03-06-2012, 12:22 PM
92 Green YJ
92 Green YJ's Avatar
I debated getting those when I had to replace and repair my rocker panels. Issue was I didn't really know how large they were or how much they actually covered. Its very hard to tell from their website. So i took some careful measurements and had my local steel supplier shear me the right size plates for my repairs. Cost me 30 bucks total for both sides. And I did the ENTIRE rocker front to back. Search my username and you should find the rust repair thread I did detailing the repairs. It was a pain but well worth it.
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
Rust Hole On Rocker Panel Justhack TJ Wrangler Technical Forum 5 12-09-2009 02:51 PM
Patching rust hole underneath body? itasor TJ Wrangler Technical Forum 3 10-06-2008 07:00 AM
Rust Hole MCJeeper YJ Wrangler Technical Forum 4 11-07-2006 09:57 PM
Cheap Rust Hole fix toplessjeep YJ Wrangler Technical Forum 4 12-22-2005 02:58 AM
Rust Hole in Floor NativeTexan YJ Wrangler Technical Forum 4 02-19-2005 05:59 PM
