rust/frame problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > rust/frame problem
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBuild your Dream Jeep with Poison Spyder's Interactive GarRuffStuff Memorial Day Sale!
Unread 10-14-2009, 01:22 PM   #1
pjmessenger
rust/frame problem
there is a spot on my frame that has rusted through...has anyone had the same problem...does anyone have advice on how to fix it?
pjmessenger is offline   Reply With Quote
Unread 10-14-2009, 01:27 PM   #2
NJscott
Pretty common ive seen much worse on the forum. a quick search will get you some threads on it.
Welcome to DaveyGeeps.com
90 islander ( de-stickered)
webber 32/34
ford dist. cap & rotor
daystar 1" bl
1.25" booms
NJscott is offline   Reply With Quote
Unread 10-14-2009, 01:30 PM   #3
pjmessenger
Have you used jeep wrap and if so how well does the product work?
Unread 10-14-2009, 04:03 PM   #4
89YJmoneypit
KMG365
89YJmoneypit's Avatar
Yep, a lot of people...
http://www.jeepforum.com/forum/f12/f...derway-150584/
If you do a search for "frame" you'll find tons of threads like this
89 YJ
Transplanted '99 4.0, AX-15, NP231
Red Jeep club #8
97 ZJ Laredo
4.0, 42re, NP242
Was my daily driver, now son's college wheels.
Marseilles Fire Dept: http://www.flickr.com/photos/4461494...th/7659346164/
89YJmoneypit is offline   Reply With Quote
Unread 10-14-2009, 04:51 PM   #5
trucknut
weld a wrap on it or cut out the rusted section and graft in some new steel. i would check all the low spots in your frame (hit it with a hammer) and see if this is the only rusted section, better to find out while parked then over a bump on the highway anything is fixable, click the link in my signature and take a look at what my frame was like!
1994 Jeep YJ 2.5
My Save the YJ from the junkyard project...
http://www.jeepforum.com/forum/f12/my-94-rebuild-thread-747404/
2001 Toyota Tundra TRD
trucknut is offline   Reply With Quote
Unread 10-14-2009, 05:13 PM   #6
windsoreight
Yeah tap around it with a hammer. Mine looked like that but once I tapped around I found more. I cut mine out with a plasma cutter and welded in heavier metal. It isn't the prettiest but it works.
windsoreight is offline   Reply With Quote
Unread 10-29-2009, 08:59 PM   #7
Larry93
He has good quality material and welds, but after installing and measuring, hammering, clamping, I realized that Daveygeeps put the shackle bushing hole 7/16" lower than it should have been. Cannot really notice in the jeep anyway.
Larry93 is offline   Reply With Quote
Unread 10-30-2009, 05:50 AM   #8
Mud-n-Beer
Rusty frame. Just had my junk fixed two weeks ago!!
I have modified rear shock mounts in the rear of my Jeep, and the drivers side was rusted thru at the frame, which took out my upper shock mount, and had about a 4" crack on my passenger side frame underneath in the back, and was loosing metal on the drivers side in the same area.
I took it to an Off Road Shop that has done this repair many times. They did a kick *** job on the repairs. The rest of my Jeep will fall apart, before these welds will.
Just try to find a good shop to do the repair, and you should be good to go, unless your frame is beyond repair.
Mud-n-Beer is offline   Reply With Quote
