Rust fix question - JeepForum.com
post #1 of 5 Old 03-11-2010, 11:26 AM Thread Starter
ryans93
Rust fix question
I've got a hole in the body right next to the parking brake, a pretty common spot. My neighbor has a plasma cutter and he offered to cut the rust out of there and do a welding fix on the hole. The question I have is, what kind of sheet metal should I look at when fixing the body? I've never welded before, but I figure this would be a good introductory.
It should be fine as long as it was "gently" rolled...
1993 YJ 4.0L 5spd Manual. OME 2.5" with 3/4" M.O.R.E Shackles & 1"BL
Not to mention the body doesn't match the frame that doesn't match the engine...
ryans93 is offline
post #2 of 5 Old 03-11-2010, 02:44 PM
timoteo1234
the tub is made out of primarily 18 gauge steel. i used 16 gauge for much of my repairs. you dont need stainless or galvanized or anything like that.
timoteo1234 is offline
post #3 of 5 Old 03-11-2010, 02:56 PM
Xtremjeep
use 16 gauge, a little thicker so it's stronger and easier to weld. Just spot weld it and jump around to reduce warping. Practice on a spare piece, it's easy to burn through.
Build Thread:
1980 CJ-7 Mall crawler (RIP 2010)
1983 CJ-8 Scrambler Full resto in progress
1988 YJ Fully Built but never Done
Xtremjeep is offline
post #4 of 5 Old 03-11-2010, 04:21 PM
warhog-06
Also used 16 gauge on mine.
warhog-06 is offline
post #5 of 5 Old 03-11-2010, 09:39 PM Thread Starter
ryans93
Thank you!
ryans93 is offline
Another Rust question? POR 15? SamlautRanger JK Wrangler Technical Forum 1 06-22-2009 08:39 AM
question about rust... merwin7 TJ Wrangler Technical Forum 12 04-28-2009 12:32 PM
new guy Rust Question dkBOVICE TJ Wrangler Technical Forum 1 02-26-2008 04:01 PM
Rust Question EpO TJ Wrangler Technical Forum 1 07-07-2007 05:03 PM
Rust question? CosmicCreeper YJ Wrangler Technical Forum 2 03-12-2005 07:44 AM
