Rust and cracks: How bad are they? - JeepForum.com
post #1 of 4 Old 07-29-2010, 08:59 PM Thread Starter
Bartleby_91YJ
Took up the carpet today to find these rust spots and cracks under the driver and passenger seats.
I don't have any experience with restoration. I have always planned to herculine the tub for years but haven't been able to get around to it.
http://img836.imageshack.us/img836/1954/dsc3920.jpg
http://img217.imageshack.us/img217/6282/dsc3918.jpg
http://img839.imageshack.us/img839/1903/dsc3916.jpg
http://img839.imageshack.us/img839/9158/dsc3914.jpg
http://img838.imageshack.us/img838/6302/dsc3912.jpg
http://img695.imageshack.us/img695/2186/dsc3911s.jpg
How would someone with experience attack this?
Appreciate the help!
-B
Bartleby_91YJ is offline
post #2 of 4 Old 07-29-2010, 09:16 PM
pasinbuy
Unfortunately your problems are pretty common. Replace the driver floor pan, and weld up the others. You do not look too bad.
pasinbuy is offline
post #3 of 4 Old 07-29-2010, 09:20 PM
TSEJEEPERS
Click free
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #4 of 4 Old 07-29-2010, 09:27 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
-B
I am by far no expert but I would wire wheel or sand all the rust areas paying special attention to the areas around the roll bar. Any soft spots have to be cut out and patches welded in. If you have large areas that are soft then you need to weld in a floor pan or partial floor pan in that given area.
There is a way to add body panels using a type of epoxy but I don't think it could be used for floor pans since they are part of the supporting structure of the tub.
The cracks could be fixed by driling a hole in the end of each crack then welding them up the cracks. If you find no soft spots then after you repair the cracks I would choose a bedliner and prep and do the liner. Prep is the key. I used Herculiner and ther UV protectan they make and it has held up well.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
fan belt cracks tommy_chunk TJ Wrangler Technical Forum 4 06-01-2008 01:44 AM
Cracks in the paint? jeeperjeff24 TJ Wrangler Technical Forum 9 09-24-2007 08:17 AM
Hairline cracks 91Jeep07 JK Wrangler Technical Forum 3 03-19-2007 06:49 PM
Door Panel cracks jtstj TJ Wrangler Technical Forum 20 01-11-2006 08:18 AM
Manifold Cracks airduds TJ Wrangler Technical Forum 2 05-08-2004 11:38 PM
