Rust in coolant - JeepForum.com
post #1 of 5 Old 12-17-2011, 11:22 AM Thread Starter
RedneckMedic
Rust in coolant
Hey guys, so I was driving my 93 YJ home this morning after letting it warm up, had no problems, then when I got home, i noticed steam coming from the engine compartment. When I opened up my hood there was rust colored fluid everywhere. One of the return hoses had a hole in it which i fixed, but as I opened up my radiator to refill it, I noticed there was alot of oxidation inside. Was wondering if anyone else has had this issue, or if its common and I just need to do a flush? Thanks in advance
RedneckMedic is offline
post #2 of 5 Old 12-17-2011, 11:36 AM
bill8bud
You can try flushing it, it will only help. Last radiator I saw like this took mtiple flushes and it was slightly better. It ended up failing a year later.
bill8bud is offline
post #3 of 5 Old 12-17-2011, 12:24 PM Thread Starter
RedneckMedic
thanx bro...would i be better off just gettin' a new radiator and saving myself the trouble, you think?
~Paul
1993 YJ, 4.0 I6: my work in progress
2000 WJ, 4.0 I6 Daily Driver
post #4 of 5 Old 12-17-2011, 06:03 PM
bill8bud
Flush it and see what happens. The one I delt with was really bad.
bill8bud is offline
post #5 of 5 Old 12-17-2011, 06:32 PM
YJames90
YJames90's Avatar
Funny you should ask,,
during my engine swap I used the chevy radiator that had rust and tranny fluid mixing with the coolant. It made a rusty/oily mess in the engine
I installed a new aluminum radiator and poured Calgon liquid dish washing detergent in the radiator and let it run hot.
I did this atleast 10 times.
Let it run hot and pulled the bottom hose for a quick release of water in the radiator.
Now im running clean and havent had anymore problems
My 2.5 to 4.3 swap thread
YJames90 is offline
Sweet Coolant Smell but No Coolant Leak? JB73 TJ Wrangler Technical Forum 4 11-07-2010 10:56 PM
89 YJ w/4.2L -->RUST, and I mean RUST in the engine!, and Carb issues jimsahm YJ Wrangler Technical Forum 8 09-07-2010 08:03 PM
I see coolant I smell Coolant But can't find leak. MrB TJ Wrangler Technical Forum 23 07-18-2010 06:33 PM
huge coolant leak/ creamy coolant?? 11Bgixx TJ Wrangler Technical Forum 17 01-11-2010 09:24 AM
Rust in coolant (Black_Jeep) YJ Wrangler Technical Forum 3 07-15-2007 10:57 PM
