Runs real rough (when cold only) - JeepForum.com
post #1 of 10 Old 09-27-2007, 07:54 PM Thread Starter
chim
My 95 4-banger (MPI) runs very rough until the engine comes up to the point that the thermostat opens, then it runs perfectly.
Until the engine gets heated up, it runs rough and stalls very easily. Most times it will keep running at a stop sign. Unless I carefully "play" the throttle to get the revs up a bit, it stalls out when I try to pull away.
When I accelerate it begins to miss badly when the revs get to about where I shift.
Strange thing is that after the stat opens, it runs like a Swiss watch - it will let me pull out from a stop with the engine at idle speed, and there's not even a hint of a misfire.
I removed and cleaned the throttle body and replaced the idle air control valve actuator, but it didn't help. Any ideas? Thanks..............chim
chim is offline
post #2 of 10 Old 09-27-2007, 08:31 PM
Jeepinjon
Have you swapped out the thermostat? You keep mentioning it...why not try that?
Jeepinjon is offline
post #3 of 10 Old 09-27-2007, 09:16 PM
Brown Dog
Vendor
Brown Dog's Avatar
Have you checked the codes? Not all codes illuminate the check engine light.
I am thinking that MAP sensor, and/or TPS (a faulty TPS does light the check engine light).
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #4 of 10 Old 09-28-2007, 08:14 AM Thread Starter
chim
Thanks, that will give me something to check. The stat was replaced ~ 2000 miles ago.
I mentioned it because the engine changes the way it runs at the point that the stat opens. You can see the temp gage peak and then drop off a few degrees. At that point, the engine runs smooth.................chim
chim is offline
post #5 of 10 Old 02-20-2012, 03:38 PM
Tre3
i have the same exact problem, i just cleaned the throttle body 2 days ago and it didn't change anything, and im starting to get worried with how easily it seems to almost stall. did you find out the problem or does anyone know if its related to the transmission? only happens it the cold i noitced it started at about 40 degrees or colder. ( just bought the jeep last summer so i dont know whats all been replaced)
Tre3 is offline
post #6 of 10 Old 02-20-2012, 03:45 PM
MaddBones702
If you have a cto valve that would be worth verifying that the lines are all connected beginning to end.
Who knew where this would go?
MaddBones702 is offline
post #7 of 10 Old 02-20-2012, 04:05 PM
Tre3
were would it be located? and how would i check to make sure everything is working? sorry im still new to trying to work on it
Tre3 is offline
post #8 of 10 Old 02-20-2012, 04:54 PM
Tre3
on a side note im leaking transmission coolant i was told, could that be any connection?
Tre3 is offline
post #9 of 10 Old 02-20-2012, 07:19 PM
oldtime_ironman
None of the above make much sense to me. When its cold the engine runs on the coolant temp sensor and the TPS, not much else. When it switches into closed loop, then it listens to the O2 sensor and all the other stuff. Closed loop happens somewhere around 185 deg F. So I would test the coolant temp sensor and maybe the wiring to/from that first. Its the temp sensor in the thermostat housing - since you replaced the t-stat, I would double check the wiring and connections to that sensor first. If thats OK, then the sensor itself should read about 185 ohms at 210 F.
Hope that makes sense and helps!
oldtime_ironman is offline
post #10 of 10 Old 02-20-2012, 09:13 PM
ParkerJ
I had the identical issue, its your crankposition sensor. Mine would run awful till it warmed up but eventually it got to the point that even when warmed up it missed, idled crazy and stalled. I replaced almost all the sensors, cleaned the throttle body and even changed the ignition coil...but after all those attempts to fix it came out to be the crank position sensor. Trust me on this, I just went through this. Good Luck
My Yj Build:
http://www.jeepforum.com/forum/f12/first-build-1991-renegade-normal-yj-1313275/
ParkerJ is offline
Engine runs rough intermittently, runs rich... Cactus737 TJ Wrangler Technical Forum 7 04-22-2010 08:40 PM
Cold=Runs Like Crap, Warm=Runs Good - Help! CheapSunglasses YJ Wrangler Technical Forum 9 11-24-2008 10:56 PM
Cold = Runs rough, Hot = Perfect chim YJ Wrangler Technical Forum 9 01-21-2007 04:19 PM
2.5 runs rough when cold slimlynn1 YJ Wrangler Technical Forum 11 04-07-2003 12:23 PM
4.2 runs real rough zuck2001 YJ Wrangler Technical Forum 7 10-01-2001 06:27 AM
