Running very rich..... Please Help - Page 3 - JeepForum.com
post #31 of 57 Old 08-27-2014, 10:39 PM
mike134
Daaaang, that regulator is expensive... 50 bucks, I wonder if we can refurb these things since everyone on the forum seems to be replacing them.
mike134 is online now
post #32 of 57 Old 08-27-2014, 11:08 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
At the junk yard I've found several that will work from 90s Chrysler mini vans. If they have fuel In them when you pull them, usually they are good. It's when they dry out that they go bad. Worth a shot if you think it's worth your time and the $2 entry fee.
Posted via my pretentious iPhone.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 AutoLockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is online now
post #33 of 57 Old 08-28-2014, 05:41 AM
Que89YJ
I read through the threads and look at what was posted. There are a bunch of knowledgeable peeps here and I don't see any reason to try and reiterate the same thing. Thumbs up.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #34 of 57 Old 08-28-2014, 09:09 AM Thread Starter
jsd1991yj
I have never had good luck in the pick a parts around me. They either dont carry the vehicles I am looking for or they are ridicuosly expensive for what you do get. I think I will just suck it up and buy a new FPR from napa. Is there any brand I should look for or stay away from?
jsd1991yj is offline
post #35 of 57 Old 08-28-2014, 09:37 AM
Luuca
Luuca's Avatar
NAPA should have a good part for it. No brands to stay away from come to mind on FPR. My pick-a-parts are chock full o' minivans. One day, I went around and pulled 5 FPR off 90s chrysler minivans. Paid $1 each for em. Needed one for YJ i was refurbishing for sale. 2 were bad, 3 were good - a big plus is that you can get the vacuum line as well. It's a little longer than the YJ, but same fittings and works just as good.
YJOTM never
Luuca is online now
post #36 of 57 Old 08-28-2014, 10:19 AM
mike134
$50 is worth it if you get your car back on the road. Just hoping you're not going to have to replace the cat after driving rich for so long...
post #37 of 57 Old 08-28-2014, 03:45 PM
Que89YJ
And that means you luuca.
Fault codes:
No Start:
Que89YJ is offline
post #38 of 57 Old 08-28-2014, 04:18 PM
Luuca
Luuca's Avatar
I'm so lost right now....
YJOTM never
Luuca is online now
post #39 of 57 Old 08-28-2014, 04:24 PM
mike134
To get your fuel pressure back down to where it is supposed to be.
post #40 of 57 Old 08-28-2014, 04:59 PM
Luuca
Luuca's Avatar
PSSSSHT... Fuel pressure - mule thresher.. I'm planing my lift, booms, SYE and cv shafts...
YJOTM never
Luuca is online now
post #41 of 57 Old 08-28-2014, 06:03 PM
Que89YJ
As far as peeps who give good advice. Mike is pretty much spot on fir support too.
Fault codes:
No Start:
Que89YJ is offline
post #42 of 57 Old 08-28-2014, 06:17 PM
mike134
How else would I fix jeeps? Mine hasn't broken yet...
post #43 of 57 Old 09-01-2014, 04:05 PM Thread Starter
jsd1991yj
Ok I replaced my fuel pressure regulator. I am now runing at 34-35 LBS and I did another leak down test and lost 1-2 LBS over 30 minutes.
post #44 of 57 Old 09-01-2014, 07:03 PM
mike134
still a tad high but way better.
I wonder if your return fuel line is a bit obstructed.
Another possibility: some people seem to have trouble with their fuel return line touching the bottom of the fuel tank slightly increasing their idle pressure.
I also wonder if this is enough to lean you out for your inspection. What does it cost to run the test out in CA?
post #45 of 57 Old 09-02-2014, 12:38 AM Thread Starter
jsd1991yj
its $40-$50 per run. Every now and then you can find a shop that will discount additional runs if you keep failing the tests.
