Running rough, code 27, exhaust smells like unburnt fuel - Page 2 - JeepForum.com
post #16 of 20 Old 05-23-2013, 05:52 AM
Que89YJ
Yes, it is worth it. It is definitely cam/crank with the symptoms. I was just helping someone who had the code 27 and it ended up being the cam when I thought it was the crank because of the symptoms. Swap it out and if it doesn't do the trick you are looking at the crank sensor.
Que89YJ is offline
post #17 of 20 Old 05-23-2013, 08:30 AM Thread Starter
nathanninja
Yeah I'll give that a shot today. I replaced the crank sensor about 6 months ago so it should be good
nathanninja is offline
post #18 of 20 Old 05-23-2013, 06:45 PM Thread Starter
nathanninja
Okay well I swapped the distributors and no change but I did a bunch of testing and long story short it ended up being a bad injector on #1. So the rough running is gone now but now I'm blowing white/blue smoke out of the exhaust. So from one problem to the next. I REALLY hope it's not bad rings
Edit: actually thinking about it, since the injector seemed to be stuck open (the spark plug I pulled was SOAKED in fuel after just a few seconds of running) so maybe that was just leaking fuel into my oil, which would make sense because when I checked the oil it seemed slightly higher than I remembered, and it smelled faintly of gas. Also the white smoke is definitely smoke not steam, and no coolant in my oil or vice versa
post #19 of 20 Old 05-24-2013, 10:49 AM
Que89YJ
did you do the fuel pressure bleed down test to find it?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #20 of 20 Old 05-24-2013, 11:06 AM Thread Starter
nathanninja
Nope I just pulled the spark plug and saw it was soaked in fuel. Tested the spark on it and it worked fine so I assumed it was the injector being stuck open. Switched it with a spare and it fixed the problem
