Running rich after O2 sensor change - Page 7 - JeepForum.com
post #91 of 99 Old 11-04-2012, 07:58 PM Thread Starter
Bad_Dog
Reset computer: Engine idles fine. First few trips - and this does involve the engine getting up to temp, stopping and cooling down and then starting back up again - the engine idles fine and throws no codes. Then I'll start it up and it'll idle rough. When it does that, I check and it's now throwing code 52. It doesn't take weeks, just me driving it about three round trips to work, or so.
But you're right, it doesn't make sense that I can drive a handful of trips and it idles fine (and there's no gas smell). And then boom, idles rough, gives 52, and I smell gas when I get out of the Jeep.
OlllllO 2013 Wrangler Sahara Unlimited
[]lllll[] 1991 Wrangler Renegade, 4.0L Auto (Retired 2013)
Bad_Dog is offline
post #92 of 99 Old 11-04-2012, 08:25 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
I wonder if the MAP sensor is the cause of your problem? When it is running good is fully warmed up and the codes are cleared pull the vacuum line off of the MAP sensor and see what happens as far as idle is concerned and what code it throws. I do beleive that a MAP sensor malfunction can trigger a code 52 and casue a rich fuel mix to happen.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #93 of 99 Old 11-04-2012, 08:55 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
OK, just some more reading...on your thread. SDGBASSE in post 43 layed out what you need to do to test the MAP sensor.
If the MAP sensor checks out go back through the postings here in and re-read everything QUE89YJ wrote. This man knows his YJ's!
My only thought is if it is fuel related and mechanical in nature like a pinched return fuel line, why doesn't it happen as soon as you go into closed loop mode when the engine heats up the first time?
post #94 of 99 Old 11-05-2012, 07:36 AM
Que89YJ
You either have a fuel pressure issue which you eliminated with the presssure readings or a bad injector. Sorry it took so long to get back. My car got hit and I had to piece it back together.
Que89YJ is offline
post #95 of 99 Old 11-05-2012, 12:28 PM
Why J?
Why J?'s Avatar
This!
Get a fuel pressure gauge and read the pressure at idle, then shut off the motor, watch for pressure to leak down. There is a spec on exceptable leak down. I don't know it off hand. If you are above that threshold you either have fuel leaking back to the tank (bad regulator) or leaking injectors.
Sorry I do not know the spec on leak down nor fuel pressure. Should be in a haynes.
Generally the ECU wont throw a rich condition code until it has seen it x number of miles or start ups or hot cold cycles. Which is why it takes a few trips for the code to set.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #96 of 99 Old 11-05-2012, 12:29 PM
Why J?
Why J?'s Avatar
In open loop the ECU ignores the O2 and is using a set table for fueling. It wont throw a code until it goes closed loop.
Mechanically the only reason he would be running rich is a leaking injector, or bad regulator allowing to much fuel pressure to the injectors.
Why J? is offline
post #97 of 99 Old 11-05-2012, 12:37 PM
Que89YJ
Yep that is exactly what I meant WHY J. The fuel pressure should be able to hold 20+ Psi for 20 minutes aftwer shutting it off. I am betting it doesnt.
Que89YJ is offline
post #98 of 99 Old 11-05-2012, 01:10 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
How come this DTC does not set during the first open loop to closed loop cycle? Leaking injector or a bad fuel regulator problems do not come and go, right?
It would be nice for anyone to came up with the right answer. The OP just wants his YJ running right!
post #99 of 99 Old 11-05-2012, 03:21 PM
Que89YJ
Do the bleed down test on the fuel pressure. I bet it's not going to hold pressure.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
TBI 4.2 running rich? renowrangler YJ Wrangler Technical Forum 3 01-20-2012 08:04 AM
Running RICH merkchop YJ Wrangler Technical Forum 5 10-06-2011 02:45 PM
Running rich......help please. daaaaaan YJ Wrangler Technical Forum 20 12-22-2006 10:20 AM
Still running rich after new O2 sensor (I think) wwiihistory YJ Wrangler Technical Forum 15 06-15-2006 09:04 AM
Running Rich? tennisjon2002 YJ Wrangler Technical Forum 7 10-25-2005 01:31 PM
