Running Problem - JeepForum.com
post #1 of 7 Old 09-05-2011, 10:10 AM Thread Starter
jeep4life1
Running Problem
I have a 92 YJ 2.5 5 speed. Ran great before I went wheeling. Now it starts to run like crap afterwards. I changed the plugs out, changed the oil, cleane the butterfly on the throttlebody, checked the fuses. Nothing works. Possible fuel pump? And help it great.
jeep4life1 is offline
post #2 of 7 Old 09-05-2011, 10:57 AM
cstone94
What do you mean by it running like crap?
95' YJ - Warn Bumpers/Tire Carrier/Winch - 2.5L - 6" Skyjacker Suspension Lift - 4.10's - Locrite Locker - Dana 35/30 - 35" BFGoodrich KM2's
11' F250 - DD
1982 Toyota Pick-Up - Spray-On Yellow Rhino Lined - Chevrolet 305 H.O. - SM465 - NP208C - All-Pro Off Road 5" Springs - 35x15.50x15 Super Swampers
cstone94 is offline
post #3 of 7 Old 09-05-2011, 12:59 PM
Mark05059
see if you ripped the o2 sensor wires out of the exhaust
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #4 of 7 Old 09-06-2011, 09:35 AM
Que89YJ
Do you have any fault codes? A little better decription of how its running would help narrow it down.
Que89YJ is offline
post #5 of 7 Old 09-06-2011, 09:39 AM
bharris68
Daily Driver
Further - define "Wheeling" - mud, water, rocks? Any branches that may have reached up there and ripped up your wiring harness anywhere?
bharris68 is offline
post #6 of 7 Old 09-06-2011, 10:49 AM Thread Starter
jeep4life1
By running like crap I mean it idles and starts fine. But when i go to drive away in gear it spits sputters and eventually bogs down to almost stalling. Like it has no power at all. And I went through some small local trails. Nothing serious or above my tires. Also checked 02 sensor and it was half way plugged in. Plugged it in and fixed some old vacuum lines. Still runs the same. No change.
post #7 of 7 Old 09-06-2011, 11:53 AM
Que89YJ
Check codes like this:
http://www.jeepforum.com/forum/f12/h...codes-1257145/
When you rehooked the O2 sensor did you disconnect the battery? It's necessary to clear the codes and get the ecu out of the default calibration. Post back what you find on the fault codes.
Que89YJ is offline
running problem halfleft YJ Wrangler Technical Forum 0 07-27-2009 11:17 AM
Running-out-of-gas Problem barkle TJ Wrangler Technical Forum 3 09-11-2006 11:45 AM
Running Problem TRF TJ Wrangler Technical Forum 3 04-17-2006 06:04 AM
running problem dwales31 YJ Wrangler Technical Forum 1 01-23-2006 11:46 AM
running problem Jay Blanton YJ Wrangler Technical Forum 1 06-15-2004 08:20 PM
