Rumbling noise from back of Jeep - JeepForum.com
post #1 of 12 Old 02-16-2010, 05:47 PM Thread Starter
Cards89YJ
I just changed out from mud tires to all terrain tires. I can now hear a lot better in the Jeep. I am now hearing a "rumbling" noise from under the rear of the Jeep on deceleration. It may be happening at other times, but I can hear it at deceleration. The "rumbling" noise sounds kind of like the brakes possibly would rubbing on the drums, but I am not applying the brakes when I hear it. It also sounds like a dry bearing possibly would.
Anyone have any suggestions.
Driveshaft?
Rear axle differential?
Universal joints?
Brakes?
Bearing?
Normal?
Also as part of this question, how much oil should be in the rear differential. I wanted to check it to make sure it wasn't dry, so when I removed the plug oil just poured out. I let it drain out to the bottom of the plug hole. Is that how much should be in there?
Cards89YJ is offline
post #2 of 12 Old 02-16-2010, 08:12 PM Thread Starter
Cards89YJ
bump
10 char...
post #3 of 12 Old 02-17-2010, 07:41 AM Thread Starter
Cards89YJ
Does anyone have any ideas?
post #4 of 12 Old 02-17-2010, 07:51 AM
Elsahara
maybe you take your rear tires off and open your drums, see if you got a lil grid on your shoes? from mudding the slit and sand made mine sound like i had bad shoes even when i wasnt braking...idk cant hurt to look
Elsahara is offline
post #5 of 12 Old 02-17-2010, 07:52 AM
86YJSEANVA
1986 YJ Wrangler
the fluid in the difefrential should be at the bottom of the fill plug hole. (haynes manuel)
rugginTJ01;9379588]yeah, driving a happy meal on wheels during crazy wind is so much fun :laugh
talentjeep;8785973] I'll go ahead and add cardboard to my regular maintenance regimen. Originally Posted by Diamond-x Didn't the 'check shock' light come on?
86YJSEANVA is offline
post #6 of 12 Old 02-17-2010, 09:58 AM
YJ-Jer
Check your drive shaft u-joints. It is common for them to make a vibration like that on deceleration when they get worn.
-Jerry
Originally Posted by unknown
"You know you drive a YJ when you run over a shadow and feel the steering wheel jerk."
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJ-Jer is offline
post #7 of 12 Old 02-17-2010, 10:11 AM Thread Starter
Cards89YJ
When you say check them, what do I need to do? I have grabbed the drive shaft and I don't seem to have any slack in it. I have a lift on my Jeep, but if you look at the picture in the link, you will see that I don't really have a bad angle where I think vibration would be caused and need an SYE.
The ujoints are greaseable. Do you think maybe they just need that?
DSC_5220 on Flickr - Photo Sharing!
post #8 of 12 Old 02-17-2010, 10:15 AM
Maxdaddy
Mine does that..not sayin its the same problem but..a piece of metal broke off in my rear diff and kinda scratched up some of the gears. Its fine i cleaned it out, but now it just makes that noise all the time. has for about 2 years..just waiting to do an 8.8 swap.
Maxdaddy is offline
post #9 of 12 Old 02-17-2010, 10:23 AM
YJ-Jer
If it were me, I'd remove the driveshaft and move the u-joints by hand. You should be able to tell if they are real loose or do not move smoothly. sometimes it is hard to tell on the jeep since the trans and diff have some play in them. only 4 bolts to take out. Just put a pan under the tail shaft or take it out with the jeep facing nose down in the driveway.
-Jerry
YJ-Jer is offline
post #10 of 12 Old 02-17-2010, 08:25 PM
dcmielec
Also might wanna maintenance your differentials. Exactly how much oil poured out? If those axles have spent any time underwater, you may have alot of water in there that'll cause some premature wear/noises.
dcmielec is offline
post #11 of 12 Old 02-17-2010, 08:50 PM
TSEJEEPERS
I would say driveshaft universals too. Heck just pull out the driveshaft and change them. They are not that exspensive and easy to change.
If that is not the problem then you can move on.
When I had a add a leaf I had the rumbling sound too. I had to go to a drop transfercase kit.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #12 of 12 Old 02-17-2010, 09:07 PM Thread Starter
Cards89YJ
I think I have a transfer case drop kit. I have 1" spacer at the 6 bolts that hold on the skid plate below the transmission and transfer case.
My Ujoints are greaseable. Should I try that first?
I do have a very small leak at the seal where the driveshaft slips into the transfer case? Could there be something in there that would rumble?
rumbling jeep 60 to 65 nowickyj TJ Wrangler Technical Forum 3 06-22-2009 08:08 PM
Low rumbling noise at end of braking/beginning of acceleration 06BlackRubicon TJ Wrangler Technical Forum 6 12-29-2008 03:45 AM
Transfer Case "Rumbling" Noise fire239 TJ Wrangler Technical Forum 16 11-25-2008 08:56 AM
Rumbling Jeep Country Boy TJ Wrangler Technical Forum 3 02-20-2008 06:37 PM
clanking/rumbling noise from 1998 TJ stewski695 TJ Wrangler Technical Forum 6 04-02-2005 09:53 PM
