Rugged Ridge SYE possible issue... - JeepForum.com
post #1 of 7 Old 10-06-2012, 02:36 PM Thread Starter
Jims-87YJ
1987 YJ Wrangler
Ok My project is just about complete (see build thread in sig). I installed a RR SYE several weeks ago I thought it went OK. about two weeks ago I was able to test drive the Jeep in front wheel drive only as I did not have my rear drive shaft. Everything seemed fine I only drove it around the block. I received my Tom Woods rear CV shaft and installed it last night and today I went to take it around the block and I have a "clicking sound" like something is not engaged all of the way? I checked and readjusted the Transfer case linage but it seemed OK. While moving if I put the TCase in neutral the noise appears goes away.
(I also my have a drive line angle issue have a thread in the eng and drive line section) but if that were the case would the noise go away when the Tcase is in neutral? I can pull the TCase if I have too but hoping I do not I really just want to get this back on the road... Thanks for any help, Jim
1987 YJ, 258, Weber 32/36, HEI, Custom Sound bar, Hardtop/Sun-rider/bikini tops, 2" Lift, 1/2" Boomerangs, 1" Body & MM Lift. 32x11.5x15 Copper STT's on Black Rock 950 Lobos w/4" backspacing, Still need Front Bumper and Seats.
My build thread:
Jims-87YJ is offline
post #2 of 7 Old 10-06-2012, 02:41 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
How much did you cut off of your shaft when you installed your SYE? Are your ujoints ok? Does it happen under power or by coasting?
Any video of the sound?
Luck Favours The Prepared
Anticanman is offline
post #3 of 7 Old 10-06-2012, 03:04 PM Thread Starter
Jims-87YJ
1987 YJ Wrangler
I don't recall exactly but it was about a 1/2 inch. If the Transfer case in in anything but N it will happen under load or while coasting. Front shaft U-joints a new (it did not happen while riding in front wheel drive with out the rear shaft) and the Rear is a brand new Tom Woods CV shaft, all appear to be in excellant condition.
My build thread:
post #4 of 7 Old 10-06-2012, 03:07 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Ok how was your chain? Can you recreate the noise and pinpoint it with the jeep on jackstands?
post #5 of 7 Old 10-06-2012, 04:04 PM
MLJeeper
MLJeeper's Avatar
Definitely sig worthy
Your limited slip differential sucks.
MLJeeper is offline
post #6 of 7 Old 10-06-2012, 04:27 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I've got a headache. Shut your face.
post #7 of 7 Old 10-06-2012, 04:53 PM Thread Starter
Jims-87YJ
1987 YJ Wrangler
I gave up for tonight, spent the last couple hours cleaning up the garage, I will tackle this in the morning. to tired and ticked off right now to even look at it any more today, I need to step away and take a breather... thanks
My build thread:
