rugged ridge sye help... - JeepForum.com
post #1 of 10 Old 05-20-2010, 10:35 AM Thread Starter
Unii
i just bought a whole np231 with a new SYE and the rear has no u joint straps where can i get them or does anyone know of the u-bolt type?
and yes i did a google search but i like hearing JF advice...
Unii is offline
post #2 of 10 Old 05-20-2010, 10:55 AM
glenn-91YJ
glenn-91YJ's Avatar
glenn-91YJ is offline
post #3 of 10 Old 05-20-2010, 11:03 AM Thread Starter
Unii
i need it for the output on the transfer case no the pinion. thanks though
Unii is offline
post #4 of 10 Old 05-20-2010, 11:38 AM
Area.3.Fiftyone
SYE's are meant to be used with CV style drive shafts.
The DC joint should bolt right to the SYE flange.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #5 of 10 Old 05-20-2010, 11:46 AM
WRMJeep
my thoughts exactly. Double Cardan joint on new axle should bolt to Transfer Case yolk
WRMJeep is offline
post #6 of 10 Old 05-20-2010, 01:12 PM Thread Starter
Unii
well i learned something new, thanks here it is by the way 180 was a good deal.
Unii is offline
post #7 of 10 Old 05-20-2010, 02:28 PM
Area.3.Fiftyone
If it's a CV style yoke, you should be able to bolt the DC drive shaft right to it as previously mentioned.
If it's a 1310 /1350 non-cv yoke, you should be able to get the straps at any auto parts store with the bolts in kit form.
post #8 of 10 Old 05-20-2010, 03:15 PM Thread Starter
Unii
on every site i see it says a cv shaft required so i should be alright.
Unii is offline
post #9 of 10 Old 05-20-2010, 03:29 PM
Area.3.Fiftyone
It really depends on what yoke is on that TC.
It could be either.
post #10 of 10 Old 05-20-2010, 03:56 PM Thread Starter
Unii
It could be either.
is there anyway to tell the difference.
Unii is offline
rugged ridge highrisetj39.5 TJ Wrangler Technical Forum 7 09-08-2009 07:22 PM
Rugged Ridge Sun Top Incursorio Wrangler General Discussion 1 08-07-2009 01:46 AM
Rugged Ridge SYE YJames90 YJ Wrangler Technical Forum 6 06-26-2009 04:02 PM
Anyone buy the Rugged ridge xhd top yet! cbn1000 TJ Wrangler Technical Forum 1 04-21-2009 06:02 PM
rugged ridge tie rod mikeypmcg TJ Wrangler Technical Forum 2 07-20-2007 12:51 PM
