rubicon transfercase in my yj - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > rubicon transfercase in my yj
Custom Tire covers for your Jeep at Jeephut.comThe Spring DynoMax rebate is here for 2015!New wheels at Jeephut.com
Unread 04-17-2010, 02:48 PM   #1
bigsquat
i know ive seen posts on putting a rubi 4-1 case in a yj but i couldnt find any when i searched. is it possible? i have a ax15 tranny and 231 now. and 6 cylinder 4.0
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD: http://www.jeepforum.com/forum/showt...hp?t=613943see
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline   Reply With Quote Quick reply to this message
Unread 04-17-2010, 03:40 PM   #2
cheapjeep71
Yeah it's possible. A friend of mine put one in his girlfriend's 95 along with the D44 Rubi axles. She has the AX-15 & had no problem bolting it up. She now has a YJ Rubicon sleeper. They even have the lockers front & rear. It is cool.
cheapjeep71 is offline   Reply With Quote Quick reply to this message
Unread 04-17-2010, 03:56 PM   #3
bigsquat
so the have the same spline count, thats good to know. i thought there might be a problem with the output flanges and my drive shafts but that would be not to big of a deal. the speedo sensor might be a problem as well. but if it will bolt up to my ax15 then i can deal with the rest. thanks. anyone else with input would be great.
Unread 04-17-2010, 05:53 PM   #4
timatoe
timatoe's Avatar
Bob, I believe it's a straight bolt on deal, it already has a flange so no need for a SYE and you get the 4 low gearing. I'm not sure about the speed sensor thing though, as when I considered this swap it wasn't an issue for me with the 4.2.
timatoe is offline   Reply With Quote Quick reply to this message
Unread 04-17-2010, 06:05 PM   #5
bigsquat
thanks tim, i was just going to pm you about it. i thought you might know
Unread 05-01-2010, 06:21 PM   #6
bigsquat
i bought the rubi 241or transfer case. its 23 spline like my 231. it comes with a 1330 cv yoke on the front. my front is a non cv 1310 . the back of the rubi case hase a flange . to make it work with my drive shafts i have to buy a front non cv yoke with 32 splines and the first 3/8" of the splines machined out or called counter bore. and ill need a different seal than the stock front rubi uses. the back seal should be ok. on the back i need to out in a 1310 cv yoke in and it has to have the same spline count and counter bore like the front. the guy gave me his linkage so ill just use it instead of modifying mine. there is a switch on the tc that tells you when you are in 4x4. i wont be needing that. the yj has on e on the vac disco housing already.
im still trying to find a good diagram to kook the wires up on the speed sensor. i thought i had hit paydirt but the colors are diferent than the one in the diagram.
my question is : will i need a body lift to put the bigger t case in?
transfercase-rear-yoke.jpg   transfercase.jpg2.jpg   transfercase.jpg3.jpg   nv241orwiring.jpg
Unread 05-01-2010, 06:45 PM   #7
Joe Dillard
Electric Chair Operator
Just install a tcase lowering kit. .....
Here's some info:
http://www.jeepforum.com/forum/f19/r...nto-yj-240140/
http://forum.neow.net/index.php?show...&#entry1322446
Joe Dillard is offline   Reply With Quote Quick reply to this message
Unread 05-01-2010, 06:50 PM   #8
bigsquat
the rubi speed sensor wires are, red , black, brown.
rubi-transfer-case-002.jpg   rubi-transfer-case-004.jpg   rubi-transfer-case-006.jpg   transfercase2.jpg
Unread 05-01-2010, 07:56 PM   #9
bigsquat
thanks joe, those links are for an automatic. i couldnt find much on an ax15 having a seal extention. it seems that people just plug the weep hole and use silicone between the mating surfaces. if the tranny leaks it can only fill the void between the cases and then its good to go. not the best case but doable. im not into having a custom seal extension made. i did send a message to tera flex about this and we will see. i think ill contact novak as well.
Unread 05-01-2010, 10:28 PM   #10
timatoe
timatoe's Avatar
I'd bet JB Conversions could answer a bunch of your questions too.
Unread 05-01-2010, 11:34 PM   #11
bigsquat
yea , ive been on there site to look at there yokes. there kinda pricey but they have a good selection of yokes for just about any application. i went ahead and sent them an email to them . thanks
Unread 05-01-2010, 11:48 PM   #12
Joe Dillard
Yea, I noticed the automatic thing, but I thought maybe some of that info could be applied or good to know.
Perhaps Tom Woods carries the yoke you're looking for.
Unread 05-01-2010, 11:49 PM   #13
Joe Dillard
Oh, BTW, you are gunna LOVE having deeper tcase gears.
You'll be close to 63:1 after the swap.
Unread 05-01-2010, 11:55 PM   #14
bigsquat
i found theb yokes at coast driveline and gear in ventura ca. the guys name is bill and he knows his stuff. he has a lot of knowlege and the best prices. the front requires a different seal and he was happy to find one that would match the tc and new yoke combo. he also will counter bore the front yoke to fit properly.
i cant wait to get this thing in!
Unread 05-02-2010, 12:08 AM   #15
timatoe
timatoe's Avatar
You actually talked to someone at 9 pm on a Saturday???? Holy schnikies that IS great customer service.
