Quantcast Rubicon Express 4 inch lift. YJ BOUNCY - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Rubicon Express 4 inch lift. YJ BOUNCY
Spartan Lockers FREE SHIPPING Excellent PricesDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJ
Old 02-12-2009, 12:12 AM   #1
sk80soarus
Hi guys, I've had my lift kit on for almost a year...and the ride is still horrible...very bouncy...
I'm wondering if there's anything I can do to help the ride?
I have TSL radials as tires...33s.
What can I do to lighten up the ride?
Thanks,
-Tom
1992 Jeep YJ Sahara 5 speed....
4" RE lift
33" TSL Radials
sk80soarus is offline   Reply With Quote
Old 02-12-2009, 12:20 AM   #2
aaronc88
correct torque on the shackles bolts?
45-50ftlbs.
aaronc88 is offline   Reply With Quote
Old 02-12-2009, 12:25 AM   #3
Tkamplin
Mmm, shocks may be part of it. I can't remember exactly how it works, but maybe you need to get a softer load-in type thing. Valved to squish a little softer in and out, not so rigid.
Just a thought.
'95 YJ, 2.5/AX-5, 1" Daystar BL, 2" BDS leafs, 33x12.50 Wrangler duratracs, Aussie locked front.
Tkamplin is offline   Reply With Quote
Old 02-12-2009, 06:15 AM   #4
TheRealOldjeep
Try swapping on a buddies tires and make sure you arn't having a problem with un balanced swapers. Even the radial TSL can be awfull hard to keep balanced.
Chuck P
94 YJ 2.5L/AW4
http://www.jeepforum.com/forum/f22/94-yj-649943/ Build Thread
www.oldjeep.com My site
www.mntrailriders.org My Club
TheRealOldjeep is offline   Reply With Quote
Old 02-12-2009, 07:32 AM   #5
champelite210
Tire air pressure may have something to do with it. I run around 25 to 28lbs in my pro comps, but your tires may be a little stiffer in the side walls. Also get yourself a set of greasable shackles. The shackles made mine ride a lot better.
1998 TJ, 4.0 HO, 5 speed, 3.5" RE Super Flex Adj SA lift, AA SYE, Currie steering, 4.88 Gears, 8.8 Rear with Eaton E-Locker, HP Dana 30 with Detroit locker and chromoly shafts, 36x12.5x15 TSL-SX, TNT Customs front 3.5 fenders, XRC rear crusher corners with 3.5 flare, A to Z rock sliders, PSC steering pump.
champelite210 is offline   Reply With Quote
Old 02-12-2009, 08:14 AM   #6
jbach
get used to it, it has leaf springs, a lift, and it's a jeep.
jbach is offline   Reply With Quote
Old 02-12-2009, 09:32 AM   #7
aaronc88
yeah try a lower tire pressure what are u running at now?
Old 02-12-2009, 12:30 PM   #8
92 Green YJ
Head Brewmaster
92 Green YJ's Avatar
some good points here. check the torque on your shackle bolts. on these you should use nylock nuts as leaving them a little looser is usually better so the shackles won't bind up as the suspension moves. Also check your tire balance and try running a slightly lower pressure. With big off-road tires usually running up to the recomended pressure on the street is too much. my Xterrains say to run at 35PSI but its way to stiff so I run them at 28 PSI on the street
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My RigRater Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline   Reply With Quote
Old 02-12-2009, 01:07 PM   #9
joe's_yj
mine rides bad too. i put bilstein 5100 on it, it helped a little
my build up http://jeepforum.com/forum/showthread.php?t=427353
Originally Posted by tawdr77 View Post
The cheapest way to get a significant power increase over a stock 2.5l, would be to pull it out and put in a 5hp briggs & stratton engine.
joe's_yj is offline   Reply With Quote
Old 02-19-2009, 03:52 AM   #10
+Crusader+
Hmm, were they worth the cash you threw down for them?
I'm considering replacing my 4yo kit shocks from my Black Diamond lift with these Bilstein 5100's ... BUT, if they are only marginally better I would rather keep 300 bucks in my wallet as extra padding for my buns?
"The only physical problem Obamacare won't be able to fix, is bustin' your @$$." – Dennis Miller
+Crusader+ is offline   Reply With Quote
Old 02-20-2009, 12:05 AM   #11
+Crusader+
BUMP
(tencharacters)
Old 02-20-2009, 04:41 AM   #12
YJames90
aka Jamesx2
YJames90's Avatar
Remove the track bars
YJames90 is offline   Reply With Quote
Old 02-20-2009, 05:13 AM   #13
jsawduste
Krawler
jsawduste's Avatar
2006 YJ Wrangler
Yes the 5150`s are worth it. I use 4 on the Jeep and 6 on the tow rig.
Money well spent IMHO>
Shackles should be greaseables, set up with Nylocks at 20-25 lbs. 45-50 is WAY to tight.
Tire pressure at around 20-25 lbs. Experiment with different pressures. Balance has nothing to do with ride stiffness. Ride quality/vibration yes.
jsawduste is offline   Reply With Quote
Old 02-20-2009, 03:33 PM   #14
RedRenegade93
I had the same problem with mine with a 2" BDS lift in it. I just installed 1" shackles and changed the bushings and that made a big difference. The ride is not nearly as bouncy anymore.
RedRenegade93 is offline   Reply With Quote
Old 02-20-2009, 03:57 PM   #15
chadroc
I had procomp ES9000's on mine. Rode horrible! I put BDS 5500's on and it is much, much better. Oh, and with TSL's..... I got the jeep with them on. I didn't check the tire pressure for a while, they clearly weren't squatting at all. They were at 15psi(did i mention they weren't squatting?). I thought I'd improve my gas mileage by putting 35psi in them. Wow! Rough ride! I backed them down to 20 the first day and left them there. If you have those tires and you run even close to recommended PSI, it doesn't matter what shocks/suspension you have, you're in for a rough ride!
chadroc is offline   Reply With Quote
Glock Forum
