rubicon air locker? - JeepForum.com
post #1 of 11 Old 01-26-2009, 05:09 PM Thread Starter
PatrickMintun
rubicon air locker?
will the air locker from a rubicon d44 rear fit a xj 44 housing? I bought a d44 from a 89xj and want to build it for my yj. I found a air locker from a rubicon rear for a good price but will it work he says it just the carrer what else will I need to buy? I already have on board air on the jeep.
PatrickMintun is offline
post #2 of 11 Old 01-26-2009, 06:48 PM
Bigboyky
somebody will correct me if I'm wrong but I thought the rubi's had electric lockers....
Bigboyky is offline
post #3 of 11 Old 01-26-2009, 06:51 PM
Goobersbro
i always heard they had air but i think they have electric becauce to make them work you press the switch and then for the rear you press the switch twice and then to disengage i think you lift it back i think.... and this would lead me to believe they are electric because air lockers have there own switch for fron and rear i dont think they share one but what do know
My marshmallow build
Goobersbro is offline
post #4 of 11 Old 01-26-2009, 07:09 PM
jaminb
i think some years had air lockers, then the swithced to electric at some point.
jaminb is offline
post #5 of 11 Old 01-26-2009, 08:18 PM
JFranko
I thought they had electric also, because air lockers=OBA, which I don't believe they have.
1992 YJ Wrangler 4.0L, NV3550, 2.5" suspension lift, 32" BFG M/Ts, lots of other cool stuff
RED JEEP CLUB MEMBER #494
JFranko is offline
post #6 of 11 Old 01-26-2009, 08:35 PM
bigsquat
i found this article talking about testing the first rubi's and it appears to have an air locker, http://www.rockcrawler.com/reviews/j...ions/index.asp
and here is an add selling one, http://portland.craigslist.org/wsc/pts/1007647804.html
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #7 of 11 Old 01-26-2009, 08:49 PM
TSEJEEPERS
I believe the TJ Rubis had air lockers. When they went to the JKs they went to electric.
No clue if they would work on a xj 44 though. I would think they would.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #8 of 11 Old 01-26-2009, 09:08 PM Thread Starter
PatrickMintun
the add
Thats the locker I was thinking of buying but I dont know if it will in fact fit and what I will beed to buy to use it. I live in portland so he is close to me can anyone tell me for sure?
post #9 of 11 Old 06-20-2009, 06:37 PM
nomad_aviator
the rubicon lockers are electrically activated and air activated. Your electric power will turn the air compressor on and the air engages your locker. I believe the PSI is somewhere in the range on 5 -6 PSI. The air pump is located on the rear of the transfer case skid or the drivers side. This is the setup on my '03, i am not sure if they moved anything in the later years. I hope this helps.
... The air lines tend to crack and disconnect themselves at the diff housing so just keep an eye on them when it starts to age.
Ah see here's your problem... You're an idiot.
nomad_aviator is offline
post #10 of 11 Old 06-20-2009, 06:42 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
why would you go out of your way to install a rubicon locker in your jeep as they are prone to failure?
spend the extra couple of bucks on an ARB, like the person you are getting the rubicon locker likely did
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
post #11 of 11 Old 06-20-2009, 07:24 PM
bigsquat
where were you 5 months ago?
bigsquat is offline
Rubicon Locker Air Pump question (how to wire your Rubicon air pump) paultyler TJ Wrangler Technical Forum 172 04-25-2017 07:59 PM
Rubicon Locker Mod 55willystruck TJ Wrangler Technical Forum 3 01-25-2011 03:57 PM
rubicon locker? crazylj TJ Wrangler Technical Forum 6 03-22-2006 07:09 PM
ok got a rubicon locker 80cj5 YJ Wrangler Technical Forum 9 10-21-2005 03:22 PM
ARB air locker vs. Rubicon locker in my TJ Glass TJ Wrangler Technical Forum 27 08-09-2005 06:23 PM
