Rubbing Noise from engine - JeepForum.com
post #1 of 7 Old 08-26-2014, 08:05 AM Thread Starter
ghetdjc320
Have what sounds like a rubbing noise coming from somewhere around my valve cover. Its almost unnoticeable until the engine warms up but even then it's not to severe. Doesn't sound very harsh either. I initially suspected something on the belt drive but I can feel the rubbing on the valve cover. Could this be a cracked exhaust manifold? I have a stroked 4.0 but it has an original exhaust manifold. Haven't noticed any loss of power either.
-DJC
ghetdjc320 is offline
post #2 of 7 Old 08-26-2014, 10:52 AM
bpounds
bpounds's Avatar
Possible timing chain you think? I know you hear it on the valve cover, but that thing is a big bell and you hear just about everything up there, so it might be misleading. The timing chain can rub the cover when the plastic guide wears out or the chain gets loose. Just an idea.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is online now
post #3 of 7 Old 08-27-2014, 09:17 PM Thread Starter
ghetdjc320
The thing is that the noise pulses along with the engine. It's not a constant rubbing noise. Good idea though!
-DJC
post #4 of 7 Old 08-28-2014, 08:20 AM
Mike Romain
I would be looking close at the bottom pulley and harmonic balancer for the slightest wobble. It also has a rubber insert that starts coming out when it is failing, but either way can cause a rubbing noise.
Mike
Mike Romain is offline
post #5 of 7 Old 08-28-2014, 01:14 PM Thread Starter
ghetdjc320
The harmonic balancer looks good. It's also new with less than 5k on stand it the locked kind that doesn't have the rubber insert. What about a rocker arm rubbing on the valve cover oil baffle?
-DJC
post #6 of 7 Old 08-29-2014, 06:44 AM
Mike Romain
Did you use a gasket on the valve cover? Have heard of some folks having issues with some engines by just using RTV. Not often though. If you have a rocker coming loose, it usually ticks before it falls off.
Mike
post #7 of 7 Old 08-30-2014, 09:34 AM Thread Starter
ghetdjc320
I used a permadry gasket
-DJC
