Rubber Hood Bumpers - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Rubber Hood Bumpers
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff Axle Simple Swap Kit!ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO
Unread 12-18-2014, 07:34 PM   #1
punchesdfw
Rubber Hood Bumpers
Does anybody have a diagram (with measurements)of where to drill the holes in my Rubber Hood Bumpers? The hood on my Daughter's YJ doesn't have bumpers.
punchesdfw is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 07:44 PM   #2
Luuca
Professional Novice
Luuca's Avatar
how often do you drop the windshield?
91 YJ "Alice" 2.5L AX5 D30/35 -Busted Knuckles Yellow Jeep Club #91
05 LJ Rubicon "Ghost" 4" RE Lift 1" BL 33s
Luuca is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 08:28 PM   #3
Reno72
Reno72's Avatar
That's funny, I lowered the CJ's quite often, even lowered the old FJ's but never in 22 years the YJ, even though it has all the hardware. I guess the roll bar spanner and rubber seals make it too much a pita.
"Says the guy driving the plastic Barbie Jeep". JLH
I have nothing against a Prius, I just wish the drivers would peddle faster.
Reno72 is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 10:59 PM   #4
Norcal_chris
Norcal_chris's Avatar
There are supposed to be rubber bumpers? Mines down all the time but I just have the 2 metal loop things.
2.5/doubler,D60/14bff,108WB,H1s,39.5IROKS 3link front w/ 14in Kings/4 link rear w/ Tj coils
Norcal_chris is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 11:10 PM   #5
timatoe
From what I understand that was just a late '95 thing, where they started using TJ parts.
timatoe is offline   Reply With Quote Quick reply to this message
Unread 12-19-2014, 12:00 AM   #6
Luuca
Professional Novice
Luuca's Avatar
Windshield bumper measurements
On our 1991 YJ we have two U-style rubber coated windshield bumpers that look like this:
The overall layout looks like this:
From the hood hinge to the bumper its 4.5 inches:
From the hoods raiser "nose bump" edge to the bumper its about 2 inches:
If you are using the TJ style round rubber "pads" on my TJ they are configured like this:
From the front edge of the hinge to the center of the pad is 6.5 inches:
From the raised hood "nose" to the edge of the pad is about 2 inches (bad pic sorry)
If you have the center footmans loop on your hood, the round pad bumper is about 10.5 inches from the edge of the loop:
I hope this helps.
Unread Yesterday, 10:12 AM   #7
punchesdfw
There we go! I Never lower the windshield, but I open the hood against the windshield all the time. Thanks Luuca, That's exactly what I needed. THANKS!
Unread Yesterday, 10:33 AM   #8
JeeperDon
Patience, Grasshopper
JeeperDon's Avatar
I think the difference in bumper height is that YJs have the wiper on the windshield frame, while TJs have them on the tub, below the fold line. The YJ needs the windshield up enough so the tips of the blades do not his the hood. It's needs less height on a TJ because of how the wipers fold.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" BFG KM2's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct.
Member and Web guy: New Mexico 4 Wheelers My Truck Page on NM4W Site
JeeperDon is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 10:33 AM   #9
Luuca
Professional Novice
Luuca's Avatar
Opening the hood against the windshield does not involve the windshield bumpers on the hood. Where the hood touches the top of the windshield frame is about 8-10 inches from the front edge of the hood. If you are concerned about damaging the hood while you are working on the engine with the hood up, I use an old beach towel placed between the hood and the windshield.
Posted via my pretentious iPhone.
Unread Yesterday, 11:03 AM   #10
JonCorwin
X2 on the bump stops only helping for folding the windshield down and not for opening the hood all the way. Only select YJs during the transition to TJs came with rubber bump stops, but those still perform the same function that our stops do.
JonCorwin is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 12:36 PM   #11
Luuca
Professional Novice
Luuca's Avatar
Excellent point to consider when you choose which style to install. Damn Don you're on fire recently. Loving the concise insights. Thanks
