rtv on a valve cover - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > rtv on a valve cover
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAwesome savings at openboxoffroad.comNitro Gear Packages Now Available at Rockridge 4wd
Unread 01-26-2015, 11:47 PM   #1
titos1997
I have a brand new valve cover with a new rubber gasket. Is it necessary to use rtv? I did notice the valve cover has a foam gasket as well. Any advice would be appreciated. Oh by the way its a 90 yj 4 cylinder
titos1997 is offline   Reply With Quote Quick reply to this message
Unread 01-26-2015, 11:51 PM   #2
timatoe
timatoe's Avatar
Nope.
I use the rubberized / steel core FelPro and use no sealant at all.
Make sure you torque it properly though. I think that has more to do with leaks than gaskets or rtv/no rtv etc...
timatoe is offline   Reply With Quote Quick reply to this message
Unread 01-27-2015, 12:20 AM   #3
Drednot
You should be fine with the foam gasket that the cover came with. Dont use rtv on it with gaskets. Can you post a pic of the new valve cover ?
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35
12 Cherokee 4x4,3.7L,
"Non Vi Sed, Arte"
Drednot is offline   Reply With Quote Quick reply to this message
Unread 01-27-2015, 01:13 AM   #4
titos1997
here is a pic of the bottom of it
Unread 01-27-2015, 03:13 AM   #5
Drednot
I'm pretty sure those are made to go on dry. Same style as the factory with the sealant already applied to the cover. Just torque and go.
As always, make sure the mating surface is clean and dry.
"Non Vi Sed, Arte"
Unread 01-27-2015, 10:57 AM   #6
titos1997
Thanks for the input
