Rpms at idle - JeepForum.com
post #1 of 8 Old 09-12-2011, 10:50 AM Thread Starter
Tikiman357
Rpms at idle
Have a 91 2.5 manual. And I am curious to see what everyone's 2.5 is idling at, mine when warm idles about 750 and is a little rough. But runs great at 1000 rpm, just wanting to see if 750 is the norm or should I turn the idle up a bit?
Tikiman357 is offline
post #2 of 8 Old 09-12-2011, 10:51 AM
Spuznick242
I would turn it up just a touch. Mine's at 800 and it's pretty smooth. If you have a rough idle though, like a loping idle it could be a vacume leak. I had it, turned out it was just a lose clamp.
DD- 1995 YJ 2.5L, Cat delete, 19lb injectors, 30/9.5r15
Trail Rig- 1994 YJ 4.0L, Rubicon Express 4.5inch lift, 1inch body, D30 Aussie, 33/12.5/r15 Cooper Mud Terrains, front bumper, rocker guards
Spuznick242 is offline
post #3 of 8 Old 09-12-2011, 11:00 AM Thread Starter
Tikiman357
I will double check my vacuum lines later today!!! Thanks
post #4 of 8 Old 09-12-2011, 11:35 AM
oldtime_ironman
Mine's at about 750 or 800 regardless of temps. It idles smooth enough, tho I bet it could be smoother with some fresh vac hose.
oldtime_ironman is offline
post #5 of 8 Old 09-12-2011, 11:54 AM
bogleparsons
Mine idles at 1100 sounds high compared to you guys.
I have TBI can i adjust it?
bogleparsons is offline
post #6 of 8 Old 09-12-2011, 11:55 AM
bogleparsons
post #7 of 8 Old 09-12-2011, 01:19 PM
bigbossd1030
Check your vacuum lines such as the one leaving your brake booster etc idle should be between 700-800
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #8 of 8 Old 09-12-2011, 02:07 PM
mrdeath2000
The tach is kind of a PITA to pinpoint your rpms between 500-1000. I assume it goes 0/500/1000 even though that second line isnt linearly spaced.
Mine idles between 700-800 when warm and does idle a little rough. If i bump it up an RCH it's smooth as hell, just havent found the right vacuum leak i guess. Might be the booster itself :/
Try pumping your brakes at idle and see if that smooths out ur idle when you do it.
93' YJ 2.5L, 4.88's, 8.8, E-Locker & LSD
mrdeath2000 is offline
