RPM surge at idle - JeepForum.com
post #1 of 3 Old 06-12-2013, 09:34 PM Thread Starter
Cashcrazy
1983 CJ7
RPM surge at idle
1989 4.2, all stock. I have recently started to get a light RPM surge after the engine is warm at an idle. I am thinking this might be a vacuum line issue with the Carter. Does anyone know if there is a known area that will cause this? It will give me a starting place at least.
Cashcrazy is offline
post #2 of 3 Old 06-13-2013, 03:45 PM
idaholtby
Well, I am a MPFI guy, but seeing how none of the carbed owners have chimed in, (Shame on you all!)then perhaps this will help you....
http://www.jeepforum.com/forum/f19/i...stops-1253726/
idaholtby is offline
post #3 of 3 Old 06-13-2013, 04:21 PM
Old4X
1990 CJ7
first before you touch anything, check for vacuum leaks. Not only the vac lines, but intake to carb mounting, intake to head mounting and EGR area. The long intake manifold can and will warp and the bolts work loose. The carb tends to loosten itself up every 18 months as does the EGR.
If you have NO vacuum leaks and your manifold vacuum is reading above 20",then look at the carb.
Go here and see if this is your problem:
http://www.jeeptech.com/engine/carter.html
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
