RPM's drop quickly between shifts? - JeepForum.com
post #1 of 6 Old 02-27-2005, 09:23 PM Thread Starter
boomhower
When I change gears on the road, the RPM's drop pretty quick (faster than normal) between shifts. What can I do to solve this problem? Was thinking it might be the TPS which might be causing my slight sputter. Will be replacing the TPS sometime soon. Hope it fixes the problem. Any other ideas?
--1991 JEEP YJ 2.5l-- (trail beater)
RE 4". AA SYE. TW driveshaft. 33" TSL's. Snorkel. Olympic Rear Bumper. Warn XD9000i. Optima Yellow Top. Herculined Interior, Grill, and Rockers. TJ Flares. Cobra 19DX CB. Firestik antenna.
boomhower is offline
post #2 of 6 Old 02-27-2005, 09:29 PM
OlllllllO Jeep1
Not sure but it sounds like your clutch is slipping.
OlllllllO Jeep1 is offline
post #3 of 6 Old 02-27-2005, 09:36 PM
JPH
JPH's Avatar
How does it idle, and does it drop faster than normal when you rev the engine without moving, or only when you are on the road and shifting gears?
'95 YJ 4.0L/AX-15
JPH is offline
post #4 of 6 Old 02-27-2005, 09:41 PM Thread Starter
boomhower
drops faster than normal without moving as well. idles a little bit low. sometimes it almost stalls but won't (thats after revving the engine up). i think it almost stalls due to the fact that the rpms drop so quickly, they just drop down to 0 and the engine would die.
post #5 of 6 Old 02-27-2005, 10:08 PM
JPH
JPH's Avatar
Troubleshoot a low idle and retarded timing. Look for vacuum leaks, (at gaskets and hoses), sensors, and maybe an idle adjustment on the linkage where it attaches to the throttle body looking thingy, (I think that is the technical term!), if you have MFI, or that is the throttle body if it is not MFI.
'95 YJ 4.0L/AX-15
JPH is offline
post #6 of 6 Old 02-27-2005, 10:15 PM
CanukYJ
CanukYJ's Avatar
It's probably crud caught in the throttle body plugging up the AIS motor and the bleed air hole which allows it to sustain idle and delay RPM drop. Get some -throttle body cleaner- and soak a bunch of it in there, then run the engine and while slightly reving it (enough to keep it moving, the cleaner will want to stall it) spray into the TB and the holes\galleys in it. That fixes alot of issues like this and it only takes 10mins, 3$, and if it doesn't work it didn't cost a ton and probably needed to be done anyways.
My jeep has only ever killed 3 things, a cat, a deer, and my wallet. What's the problem officer?
1992 Red YJ. Lifted, locked, and loaded with beer (Disclaimer: This doesn't mean said driver endorses drinking and driving, please enjoy alcohol responsibly and do not operate any vehicle of any kind, thank you....)
Thanks to the price of gas here ($4.25 a gal) I just bought a mountain bike, 0" of lift, 0" of travel, MT's, locked rear axle, oh yeah, it's the sh#$.
CanukYJ is offline
Transfer Case Drop Question...To drop or not to drop? dswi YJ Wrangler Technical Forum 11 07-24-2009 02:33 PM
when i stop, rpm's drop and engine dies redbob2323 TJ Wrangler Technical Forum 11 04-29-2009 08:40 AM
Need help quickly!! danny2go YJ Wrangler Technical Forum 6 03-19-2009 11:41 AM
4.0 stalls occansionally when RPMs drop quickly Chad184 TJ Wrangler Technical Forum 4 10-10-2008 12:54 AM
RPM's drop on hard turn... XJeffro TJ Wrangler Technical Forum 8 12-17-2006 06:40 PM
