RPM on the highway - JeepForum.com
post #1 of 16 Old 09-04-2011, 04:09 PM Thread Starter
wanabejeeper
1987 YJ Wrangler
RPM on the highway
I'm thinking about regearing, whats a reasonable RPM while on the highway 65-70 mph with a 4.2 engine.
87 YJ The Original!
It goes in that barrel you wheel out to the street once a week.
My build thread
wanabejeeper is offline
post #2 of 16 Old 09-04-2011, 04:16 PM
oldtime_ironman
Maybe its just me, but I've always tried to keep my cruise RPM's around 2500 no matter what kind of engine. That's why I'm so interested in the new 6-speeds. Low RPM's == longer life and better MPG's.
oldtime_ironman is offline
post #3 of 16 Old 09-04-2011, 05:03 PM
Desert_Rampage
1991 XJ Cherokee
^^ What Ironman said!
"Chainsaws can dismantle anything... Or you can just take it apart by removing screws until it opens, but what fun is that? "--Motoman22
Desert_Rampage is offline
post #4 of 16 Old 09-04-2011, 07:17 PM
mxmike480
My 89 with 3.07s & P235/75s turns around 2100 @ 70mph.
89 Wrangler, 99 Cherokee,(Watch this space for all the mods that I will do to them)
mxmike480 is offline
post #5 of 16 Old 09-04-2011, 07:26 PM
Yonco
31 x 10.5 x 15's with stock 3.55's on my 4.0 run about 2500@ 65 mph. Which is where i keep it at when on the highway, or i run about 55 and take it easy. I couldnt even imagine having a closer ratio than this, i have enough power with these gears and its still high rpm on the highway.
NEW JK:
OLD YJ: http://www.jeepforum.com/forum/f22/1991-yj-project-quickie-1146445/
Yonco is offline
post #6 of 16 Old 09-04-2011, 07:32 PM
ClarkRCC
My 90 has got the 4.2 ax15 and 3.07 with 31 10.50's and do 70 at 2000 rpm's and manage to pull 21 mpg
Just keep going till it sounds expensive
ClarkRCC is offline
post #7 of 16 Old 09-04-2011, 07:44 PM
notmyj
Mine does 2200 at 65. 35's, 4.88, with an AW4 from an XJ.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #8 of 16 Old 09-04-2011, 08:10 PM Thread Starter
wanabejeeper
1987 YJ Wrangler
So what I'm hearing is stick with the 3.07 gears even with my 33's? Wow just not what I would expect reading all the regear threads. How is your acceleration off the line? Wheeling performance is acceptable too?
87 YJ The Original!
My build thread
post #9 of 16 Old 09-04-2011, 08:21 PM
oldtime_ironman
Even though I don't have one at the moment, I would imagine that the sheer torque from the 6-cylinder makes up for a lot of gears.
I would be more worried about eating up a lot of clutches with such a stiff gear ratio and engine torque.
post #10 of 16 Old 09-05-2011, 03:21 AM
Tongie
I had 3:07 in my 4.0, 5 speed and when I went to 33 inch tires, it couldn't pull itself up a hill on the highway. Forget about and crawling or offroading. Went to 4:88's and couldn't be happier. Runs about 2500 rpm at 65 mph, 3000 rpm at 72 mph. Seems the 4.0 likes to run the best at 2500 rpm.
Tongie is offline
post #11 of 16 Old 09-05-2011, 04:45 AM
Yonco
When im on the trails i am in 4x4 low EVERYTIME. I am geared a little higher than you, but i can just crawl it at idle and it will climb up some really steep angles and i dont even have to gas it for more torque.
NEW JK:
Yonco is offline
post #12 of 16 Old 09-05-2011, 04:52 AM
badmax
you do not want 3.07's with 33's.... it will be a dog.. i had 4.88's in my last jeep, it had an ax-15 & 33's. It turned 2500 at 65 mph. I would go no less than 4.56 gears. JMO and everyone has an opinion.
badmax is offline
post #13 of 16 Old 09-05-2011, 06:16 AM Thread Starter
wanabejeeper
1987 YJ Wrangler
its interesting because the calculator i'm using http://www.grimmjeeper.com/gears.html shows my setup tf909, np203, 3.07 gears, turning 33's at 64mph at 2000 rpm mabe a tad low. going to 3.73's moves it to 53 at 2000 which is starting to get to high. Whats the final drive on that 5 speeed? I'll bet its less than the 1:1 I'll be using
Most of the rural roads near my house are 50-55 and I drive them at 60-65. Not to mention the higway.
87 YJ The Original!
My build thread
post #14 of 16 Old 09-05-2011, 06:48 AM
oldtime_ironman
Final drive on the 5-speed is in the neighborhood of 0.72 to 1.
post #15 of 16 Old 09-05-2011, 07:39 AM Thread Starter
wanabejeeper
1987 YJ Wrangler
I'm thinking I could find a yj with a 30/35 combo with 3.54 gears and just bolt that in cheaper than re-gearing and have ust about the perfect setup for me.
87 YJ The Original!
My build thread
10 mpg on the highway, is this even possible? Eric90xj TJ Wrangler Technical Forum 15 03-30-2011 07:32 AM
12 mpg on highway?? quag1509 JK Wrangler Technical Forum 50 07-11-2010 05:08 AM
4.88s on the highway?? b0bbymc TJ Wrangler Technical Forum 32 07-16-2009 01:26 PM
10.9 MPG on highway tx-Skydiver JK Wrangler Technical Forum 12 02-26-2007 09:16 AM
No top end on the highway, help! magnato1 TJ Wrangler Technical Forum 15 08-03-2005 12:19 PM
