RPM Gauge not working - JeepForum.com
post #1 of 5 Old 09-01-2011, 11:20 PM Thread Starter
Jrcoyotes21
does anyone know how the RPM gauge works? is there a sensor for it? is this a common problem? when i turn the ignition to on, the needle moves up to zero but then it just stays at zero even when the engine is running.
thanks for any help
Jrcoyotes21 is offline
post #2 of 5 Old 09-02-2011, 04:10 AM
dodger889
First there is no sensor for the tach. It gets it's signal for the ECM. You should check the connection on the back of the speedo-tach panel for corrosion.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #3 of 5 Old 09-02-2011, 06:34 AM
Berniebikes
I've got an 88 so mine may be different, but the tach gets its signal from the negative terminal of the coil. It's a light green wire on my vehicle. I suspect that all YJ tachs work the same, but will wait for some more knowledgable gurus to chime in.
Berniebikes is offline
post #4 of 5 Old 09-02-2011, 12:42 PM
GromMudder757
Do what charger said they are known for corrosion! then again its a jeep everything is known for corosion on em.
Zak
GromMudder757 is offline
post #5 of 5 Old 09-06-2011, 05:28 AM
larry408
I have one from a 91 YJ that I will sell if you need another one.
USAF 1968-1972
NRA Life
1991 YJ
1973 Dodge Dart Sport
1980 Honda CB900c
larry408 is offline
Gas Gauge not always working bmxrules39 TJ Wrangler Technical Forum 14 09-01-2010 08:23 PM
Gas Gauge Not Working HELP PLEASE trailmaker YJ Wrangler Technical Forum 15 08-01-2010 09:18 AM
Gas Gauge not working bshae342 YJ Wrangler Technical Forum 5 11-08-2009 05:05 PM
Gas gauge not working, why? tporter YJ Wrangler Technical Forum 4 07-21-2007 09:04 PM
Gas Gauge not working hipsinking YJ Wrangler Technical Forum 9 06-15-2004 10:55 PM
