Royal purple ruined my tranny, so what damage? - JeepForum.com
post #1 of 53 Old 03-30-2010, 05:04 PM Thread Starter
trw
2011 JK Wrangler
tranny shifting problems, tranny or clutch?
I ran Royal Purple Synchromax in my AX15 for 11,300 miles now (I bought this tranny brand new from Advance Adapters), and now I'm having problems getting it into gear sometimes.
I was recommended the oil by Napa, whom I asked "would it work in an Aisin transmission with brass synchros?" to which he replied "yes". Now I cannot shift it sometimes!
I changed the Royal Purple oil out with Pennzoil synchromesh and I was able to shift it perfectly fine for a few days before the problems came back again. What will happen is I will coast to a stop with the tranny in nuetral, and when the light turns green and I go to put it in 1st, it wont go into 1st at all, or any gear until I've wrestled with it. Eventually it will drop into 1st, then it will shift fine and smoothly for a little while until it acts up again.
now upon researching the oil, it is for use in trannies that require ATF spec oil so having essentially dumped ATF (thinner viscosity than 75w90) into my AX15, is there any damage it may have done? Is this a synchro problem or a clutch problem? and if tranny related, would just replacing the synchros do? or would there be more permanent damage to the gear sets or anything?
Jeep garage:
2011 Jeep Wrangler JK - 33" BFG KM2s, 2.5" RC BB, ARB bumper, IPF 900XS, Superwinch EPI 9.0, AEV Snorkel
1995 Jeep Wrangler - 4 cyl, 2.5" lift, BFG AT 30s, Ford 8.8, SYE+CV, AX15 swap, ARB snorkel, Aussie locker + loads more - sold
1978 Jeep CJ-7 - 304 V8, TH400 auto and quadratrac
2007 Jeep Liberty - Mother's Jeep, BFG ATs and....mud?
trw is offline
post #2 of 53 Old 03-30-2010, 05:19 PM
themonkeyman
1987 YJ Wrangler
The not getting into gear at a stop light almost sounds like it could be a clutch engagement issue. I'd start by putting in some Redline MT90, but I would also double check by giving the clutch a fresh bleed.
Might be worth having some of your used trans oil analyzed for brass content.
themonkeyman is offline
post #3 of 53 Old 03-30-2010, 05:32 PM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
I use 10W-30 motor oil (about the same viscosity as 75W-90 gear oil, uses a different viscosity scale, so different numbers). It's obviously ok with brass, since our crank/rod bearings and valve guides don't fail.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is online now
post #4 of 53 Old 03-30-2010, 06:03 PM
monkeyhouse
I am not a transmission expert(I only play one on TV, lol) but I was just wondering if possibly you had a seal somewhere that might be leaking. I know it's new, but since you said it originally was fine and then when you changed the oil it was fine at first, just wondering if the fliuid level was low? Just thought I'd throw that out, probably not the case, but easy enough to check out.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #5 of 53 Old 03-30-2010, 06:07 PM Thread Starter
trw
2011 JK Wrangler
I actually had shifting problems before I did anything to the tranny, I changed the oil thinking it may be the oil causing my issues. I was having shifting problems on the Royal Purple oil and then had it come back a few days after putting Pennzoil Synchromesh in it.
I do have a leak at the Tcase where ATF is coming out (I use Mobil 1 ATF in that), but never had I been leaking tranny fluid.
Jeep garage:
trw is offline
post #6 of 53 Old 03-30-2010, 07:22 PM
monkeyhouse
Okay, just thought I'd throw it out there. Don and mean max are extremely helpful with drivetrain issues, they'll get ya straight!
post #7 of 53 Old 03-30-2010, 07:40 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
I've been running royal purple syncromax for years now in my YJ w/o any problems at all Maybe your tranny was on the way out and the new fluid helped speed it up
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #8 of 53 Old 03-30-2010, 07:42 PM
gbeltran
Just wondering where the brass is? I know they make bronze valve guides, don't think any production stuff comes with it though from Jeep.
gbeltran is offline
post #9 of 53 Old 03-30-2010, 07:48 PM
ionakana
Grand Poobah
ionakana's Avatar
I put synchmax in my tranny as recommended by a mechanic, it ran great for a few thousand miles then it started getting hard to shift. I just happen to bump into a family friend who rebuilt trans for 40 years and was told to get that crap out of my transmission. I switched to Royal purple gear oil and everything has been fine since. I'm going to try 10w 30 on the next fluid change. If I were you I would go to wal-mart and get some cheap 10w30, it may solve your problem. If it does then get some good oil in there.
Psalm 14:1
Live in Georgia? click here-->
ionakana is offline
post #10 of 53 Old 03-30-2010, 07:56 PM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
Originally Posted by gbeltran View Post
Just wondering where the brass is? I know they make bronze valve guides.
Actually I think they just refer to the GL-5 gear oil as not nice with 'yellow metal', which I understood to include brass and bronze.
Web Admin for
post #11 of 53 Old 03-30-2010, 07:59 PM
NonRubicon
...What will happen is I will coast to a stop with the tranny in nuetral, and when the light turns green and I go to put it in 1st, it wont go into 1st at all, or any gear until I've wrestled with it. Eventually it will drop into 1st, then it will shift fine and smoothly for a little while until it acts up again. ... Is this a synchro problem or a clutch problem?
I had a similar situation with a Ranger. Difficulty shifting, and sometime unable to get into gear after stopping in neutral. Showed up particularly after the transmission warmed up. I thought my problem was synchro related, but replacing the clutch cured the shifting issue. Turned out the my pressure plate assembly was worn out among other things.
If bleeding the clutch and replacing the old hydraulic fluid doesn't solve the problem you might be looking at repairing/replacing the clutch. Since you are having problems shifting into any/all gears it would likely be a clutch disengagement issue, not every synchro gone bad at the same time. That is, unless when you drained the trans fluid it looked like you struck a goldmine.
NonRubicon is offline
post #12 of 53 Old 03-30-2010, 08:25 PM
idaholtby
Your problem sounds to be hydraulic pressure related. The master cylinders sometimes fail to were the pressure leaks past the piston in the bore (internally so that no fluid is lost). This prevents a loss of pressure being transfered to the slave for proper friction plate engagement. Check for brake fluid leaks at the firewall under the master and at the bottom of the bell housing. If clutch fluid level in the reservoir is fine, and the system is well bled, I would bet money on the master going bad.
idaholtby is offline
post #13 of 53 Old 03-30-2010, 08:28 PM
1993BlackYJ
I just had my Tranny rebuild and filled it up with Royal Purple... Do I need to change it? Is it the wrong stuff.
1947 CJ-2A
1953 CJ-3B "Ray"
1957 CJ-3b "Jeep with no Name" Parts Donor
1971 CJ5 "Dorothy" 225 Dauntless V6
1993 Black YJ 4.0L, 5 speed, Posi-Loc, 35x12.50 MTZ, 4" Skyjacker lift, Ramsey 8500 Winch, OBA, Front Aussie Locked, 8.8 ARB Rear, 4.10s
My 93 Build Thread Over 700pics :
My 71 "Dorothy" Build Thread Lots of pics :
My 53 CJ-3B "Ray" Build:
Jesus Christ is my Lord and Savior
1993BlackYJ is offline
post #14 of 53 Old 03-30-2010, 08:40 PM
idaholtby
Royal purple is fine. Only thing you need to avoid is GL-5 gear oil that typically has sulfur additives because the sulfur will attack the synchros.
post #15 of 53 Old 03-30-2010, 10:02 PM
ritjobbie
According to BobIsTheOilGuy, GL-5 hasn't been bad for yellow metal in about ten years. Any GL-5 on the shelf today is buffered to attenuate/eliminate the destruction of yellow metals.
With that said, my AX5 won't shift for beans (especially in the cold) with any GL-5 oils. Redline MTL all the way.
1995 YJ Rio Grande, 2.5L Low Output Engine
ritjobbie is offline
Royal purple shinigami YJ Wrangler Technical Forum 20 01-13-2008 11:21 AM
AUTO TRANNY FLUID > Royal Purple? msavard TJ Wrangler Technical Forum 18 11-07-2006 06:44 PM
Royal Purple...where to buy?? primus TJ Wrangler Technical Forum 7 10-04-2006 09:05 AM
What weight royal purple for tranny and axles? Bot YJ Wrangler Technical Forum 1 01-30-2006 11:05 AM
Guess I am the Royal Purple tranny fluid test pig? IAJack TJ Wrangler Technical Forum 11 01-27-2005 06:09 PM
