rounded head on bellhousing bolt???? - JeepForum.com
post #1 of 22 Old 04-12-2010, 07:12 PM Thread Starter
wildride89
2014 JK Wrangler
i have been having issues with my jeep and with the help of this site and my neighbor it was narrowed down to the throwout bearing. i purchased a clutch kit from the neighborhood advance auto which came with the slave cylinder/bearing, pilot bearing/bushing pressure plate, alignment tool and clutch plate. i have never attempted removing transmissions or anything like that before but i figured what the hell and decided that it would be a good learning experience. i have since removed the front rear driveshafts, various lines to and from transfer case, the brake line from cylinder in bellhousing, exhaust since i couldnt clear the removal without it, and finally arrived to the point to where the bellhousing had the mounting bolts left in that. i removed the 6 bolts around the side and didnt know there was two more bolts at the top which my neighbor pointed out to me and he offered to help and didnt turn it down. since he has a jeep and has had one for a long time i figured he knows way more than me and he proceeded to try and take them out. turns out he thought that they were one size and it turned out to be inverted star heads and he ended up rounding off the head before i got back from the store with the set of star sockets. my question now is does anyone have a good idea as to how i can get that top left bolt out???? its definitely stripped because i put the right size socket on it and it was already too far gone. any ideas or info is appreciated thank you
wildride89 is offline
post #2 of 22 Old 04-12-2010, 07:18 PM
Burnerman
Burnerman's Avatar
Weld a nut on it. Those 2 bolts are 2 I hope I never strip. They are a PITA to even see. If you drop the trans down on a jack and remove the shifter cover you can get to them better. You could try to pound a cheap socket on it. Those 2 bolts get the highest torque when they get tightened so they're in there.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #3 of 22 Old 04-12-2010, 07:25 PM
YJake
Gah... I've had to mess with those too many times on 4.0 rigs!
My advice would be to let the tranny sag so that you have more room to work with in there and try to either weld a nut on the end or..... Hrmmms..... Drill it out?
Good luck, I feel your pain!
Jake
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
post #4 of 22 Old 04-12-2010, 07:58 PM
jay-h
I was just in Home Depot the other day and saw a special socket for digging into and removing rounded head bolts. Can't tell you how well it works, though. I have successfully used a small pipe wrench on rounded heads, but you need some clearance for the wrench.
jay-h is offline
post #5 of 22 Old 04-12-2010, 08:04 PM
little_Jeep
X2 on the above advice.......... once you get those bolts out, toss them in the trash and replace them with some nice hex bolts.
little_Jeep is offline
post #6 of 22 Old 04-12-2010, 08:08 PM
erockz
Buy these. They work amazing. Trust me I own them and am a mechanic. I use them all the time. A must have in your toolbox. http://www.sears.com/shc/s/p_10153_12605_00952166000P
erockz is offline
post #7 of 22 Old 04-12-2010, 08:11 PM
Burnerman
Burnerman's Avatar
^^^ x2 I just thought about them. I have used them a couple of times and they just might work.
96 ZJ.
post #8 of 22 Old 04-12-2010, 08:12 PM
Louie4
The torx head bolts on the top of my AX-15 rounded. I lowered the tranny and took an old 3/8 socket, unknown brand, and tapped it over the bolt head with a hammer then I was able to get it off.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #9 of 22 Old 04-12-2010, 08:49 PM Thread Starter
wildride89
2014 JK Wrangler
thanks guys youre the best also the freaking flange coming down from the exh manifold i sheared off that bolt too but i guess what can you expect hardware conditions to be on a 21 year old jeep thanks again im going to give you an update when i get back to it
post #10 of 22 Old 04-13-2010, 05:20 AM
Louie4
I think Autozone has some replacement studs you can get.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #11 of 22 Old 04-13-2010, 06:19 AM
Nucklez
I was going to post the same set man! I have some of those, and had to use them when getting the exhaust off of the manifold. They were actually strong enough to break the bolt in half, even though the head was rounded off! Those things are amazingly strong! By the way, even my local machine shop couldn't tap the rest of the bolt out of the manifold. He had to drill and tap me another hole right beside that one.
88 YJ Sahara
3" Suspension Lift, 1" body lift, Rear Shackle Conversion
Superior Rear Axles and Rear Locker 4.56 Ring Gear
Warn Front Axles
Howell TBI
Nucklez is offline
post #12 of 22 Old 11-26-2014, 12:55 PM
JayBJordan
My son bought a 96 Cherokee and the clutch went out. We are having a bear of a time getting these top two transmission bolts out. We've stripped the heads. We tried tapping another attached to the end of the extensions on these bolts, but with no luck so far. We have also tried the Craftsman bolt extractor, but can't get them to grip. I have seen mention of some people using a grinder to grind the heads off. Are you just using a normal angle grinder to do this? It looks like it would be difficult to get the grinder down there from up top to do this. We don't have a welder, so we can't weld a nut on. We're looking for some guidance here.
JayBJordan is offline
post #13 of 22 Old 11-26-2014, 01:18 PM
SadDayPanda
I torch them off and replace them. gottcha be careful but its the fastest way, and you can reach them from the engine bay.
87, 93, 95 YJ
92, 98 XJ
87 J10
SadDayPanda is offline
post #14 of 22 Old 11-26-2014, 06:40 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
The best way I have found to get to bellhousing bolts is to raise the motor, remove the mounts, then lower the motor down.
Then it's the abuse of your choice.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #15 of 22 Old 03-14-2015, 01:33 PM
sipper
I'm having the same problem I've tried every kind of extractor I could buy tried the Irwin the craftsman and the gator grip none will grip it it's to far gone so I'm thinking I'll have to torch it out but I'm a little worried bc i know the bellhousing will heat up a lot faster that the bolt will been working on it over a week now
sipper is offline
Driveshaft bolt head rounded off gdl TJ Wrangler Technical Forum 10 03-26-2010 11:07 AM
rounded bumper bolt CaleTJ99 TJ Wrangler Technical Forum 4 10-24-2009 12:50 AM
rounded bolt head. help motorhead0320 YJ Wrangler Technical Forum 6 01-03-2008 04:40 AM
hinge bolt head rounded off tjsooley TJ Wrangler Technical Forum 10 04-20-2006 10:01 PM
stripped upper bellhousing bolt head (3/8)" jeepnpilot TJ Wrangler Technical Forum 4 08-20-2004 11:35 PM
