Round Tail light Guys-HELP - JeepForum.com
post #1 of 4 Old 10-17-2006, 11:57 AM Thread Starter
jeepnmike
jeepnmike's Avatar
Hey guys-
I just got done wiring up 2 round tail lights and a white light for back up. But, Im having problems with the back up light. Somehow, the reverse light wires are tied into the guages and since I had it wired wrong, it was blowing the cluster fuse everytime I put the Jeep in reverse. Could someone tell me how they wired their single reverse light up/how they grounded it?? Thanks
'95 YJ- 1.25" BL, 31" bfg's, black cragars, herc'd tub. sold
'99 TJ Sport- 35's, 8.8, 4.88s, 5" RC LA, JB SS SYE, UFC TT, HD steering
jeepnmike is offline
post #2 of 4 Old 10-17-2006, 12:17 PM
Magnum
Does your new white light simply have two wires out of it? If so, one may be internally connected to the case so that it can be grounded either through the mount or through the ground wire. You probably have your hot wire from the backup switch connected to this ground wire, which is shorting through the case to ground. If so, just swap the two leads coming out of your new white light. If it is set up some other way, forget everything I just said.
-- Jim
Magnum is offline
post #3 of 4 Old 10-17-2006, 01:11 PM
ar4130
1997 XJ Cherokee
try looking in this write-up.
Hope this helps
http://www.links4jeeps.com/writeups/...ts/page_3.html
ar4130 is offline
post #4 of 4 Old 10-17-2006, 01:35 PM Thread Starter
jeepnmike
jeepnmike's Avatar
hey yea that link is it thanks a lot!
Round 4" LED tail light install! Mean Max YJ Wrangler Technical Forum 108 01-31-2016 08:09 PM
Nooooo! Not the round tail light! Brokagain YJ Wrangler Technical Forum 18 11-07-2007 07:05 PM
2003 round tail light installation? jeeperjeff24 TJ Wrangler Technical Forum 7 09-25-2007 03:09 PM
Round tail lights? TheBoogieman TJ Wrangler Technical Forum 10 09-22-2006 07:29 PM
