Round LED lights for the rear of my YJ. Question? - JeepForum.com
post #1 of 14 Old 06-04-2010, 10:35 PM Thread Starter
Jeeper_YJ
I am going to put some 3" (not sure correct size) round LED lights in the rear of my YJ. I was told I will get a fast blink? How do I fix this?
Thanks.
'97 Cherokee, 99+ intake, 62mm TB, 703 injectors (new), k&n intake, Hypertech III, 180* stat (1/8" drilled hole), 2.5" manifold 2 tail pipe (Hooker Maxflow & hi flow cat), Perf header, 4.5" zone lift, 32" GY Dura Trac, Rear head rests. Comp cam "231" & Perf head (LS1 BIG valves 2.02/1.62). 3 row alum radiator.
Jeeper_YJ is offline
post #2 of 14 Old 06-04-2010, 10:40 PM Thread Starter
Jeeper_YJ
Yes, I did a search. Forgot to add I found this link.
LED Tail Light Turn Signal Modification
It says I need a Tridon Stant EL-12 flasher in place of my existing flasher. Anyone have a part number?
Thanks
post #3 of 14 Old 06-04-2010, 10:41 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
http://www.jeepforum.com/forum/f12/h...lights-976895/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 14 Old 06-04-2010, 10:42 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Thanks
EL-12 is the part number.
Max
Mean Max is offline
post #5 of 14 Old 06-04-2010, 10:45 PM Thread Starter
Jeeper_YJ
Napa or Kragen have it?
What did you use for reverse?
Thanks Max, quick and sweet!
UPDATE:
http://www.napaonline.com/Search/Det...L12_0226732413
post #6 of 14 Old 06-04-2010, 11:01 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Skip the Tridon unit, mine failed in a years time and wouldn't work with LED's all around (I'm running front LED turn signals as well) Pick up the Blazer electronic flasher from Autozone -- Seems to be a much beefier unit, and works with LED's on all 4 corners.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #7 of 14 Old 06-04-2010, 11:01 PM
timatoe
timatoe's Avatar
Any auto parts store will have the EL-12, if you don't see it, just ask for an electronic flasher.
For reverse lots of people use some cheap off road lights mounted under the bumper, that's what I had for a while. When I built my new bumper, I integrated some 2" LED's into the bumper.
timatoe is offline
post #8 of 14 Old 06-04-2010, 11:05 PM Thread Starter
Jeeper_YJ
Where did you get those reverse lights web link?
Treat me like a 3rd grader! Part number?
post #9 of 14 Old 06-04-2010, 11:29 PM
timatoe
timatoe's Avatar
Don't remember the seller, I went to eBay and typed in 2" LED's. They were about $20 for the two lights, grommets, and pig tails. I sent MeanMax some oblong ones I was originally gonna use, someday he'll stop fixin' everyone else's stuff and build his bumper to show off.
timatoe is offline
post #10 of 14 Old 06-04-2010, 11:32 PM Thread Starter
Jeeper_YJ
<---Laughing. Were never done fixing these dang Jeeps.
Thanks for the heads up.
post #11 of 14 Old 06-05-2010, 08:49 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Just to clarify, Blazer is the manufacturer for the flasher unit, its not for a Chevy Blazer. Pick up the correct flasher for your YJ made by Blazer.
-Matt
White '94 YJ Sport
UltimatE is offline
post #12 of 14 Old 06-21-2010, 06:22 PM Thread Starter
Jeeper_YJ
I ended up using this and it works on a 1993 YJ. My turn signals are back! Total cost $9
EF32RL Electronic 2 pin Turn Signal Flasher LED Compat
EF32RL Electronic 2 pin Turn Signal Flasher LED Compat.: eBay Motors (item 110503583845 end time Jul-04-10 23:15:16 PDT)
post #13 of 14 Old 06-21-2010, 07:22 PM
1992 renagade
Heres the lights I plan to use on the rear of my YJ although they are not flush mount they only require 3 small holes and have a very bright reverese light.Maxxima: Hybrid Series 4" Round Flange Mount, Back-up & Stop/Turn/Tail with 27 LEDs
Neill
1992 black Renegade
4.0L 5spd. 4:10 gears 33x12.50 BFG KM 2's A to Z fabrication front and rear bumpers and cage
1994 YJ Sahara Project Bean
2000 Jeep Cherokee Stock
AtoZ Fabrications
Blue Mountain Jeep Alliance
Delaware jeep Association
Screw the HOA. More guys just need to start doing man things in the garage.
Originally Posted by aw12345 View Post
Jeeps are like mistresses, they take all your money, but boy what a ride!
1992 renagade is offline
post #14 of 14 Old 06-21-2010, 08:20 PM Thread Starter
Jeeper_YJ
The ones I got are DOT approved. I also noticed that the ones you posted have 9 red led's and mine have 18 leds for red.
Although, I do like those, I am glad I got the DOT approved ones and they are brighter with double the leds.
YJ Rear Round Tail Lights? denwagh YJ Wrangler Technical Forum 32 02-26-2013 06:11 PM
Anyone try these (7" LED Round Lights)? riptide Wrangler General Discussion 40 09-05-2010 07:01 AM
Square lights to round lights and grill? profile YJ Wrangler Technical Forum 16 10-08-2009 01:14 AM
Round Lights Lee3333 YJ Wrangler Technical Forum 18 06-01-2008 03:54 PM
My new round tail lights H8PVMT TJ Wrangler Technical Forum 32 07-19-2004 07:02 PM
