Round 4" LED tail light install! - Page 8 - JeepForum.com
post #106 of 110 Old 12-18-2011, 06:21 PM
panaceabeachbum
Originally Posted by 91BoD View Post
any advice on where to make the cut in relation to the 3 holes?
Do most armor corners have the light in this position?
the metalcloak corner gaurds have a pilot hole to mark the location, although I would move them up about 1/4" so the rubber grommet doesnt over lap the filler insert.
panaceabeachbum is offline
post #107 of 110 Old 07-14-2014, 10:26 PM
hart427
i just installed these same lights from harbor freight, i installed them in my buddies garage and as soon as i got home they stopped working. no signals no brakes nothing. i checked the fuzes and i changed the brake light switch cause it was $9 but it didn't fix it. any ideas on the issue?
hart427 is offline
post #108 of 110 Old 07-15-2014, 03:57 AM
timatoe
timatoe's Avatar
Check your grounds.
timatoe is offline
post #109 of 110 Old 01-31-2016, 07:09 PM
bcox76
YJ Led lights problem
I have a 95 YJ that I did the custom 4" grommet lights they work awesome. But I have 1 problem the left light works as it suppose to but the right light with the headlights on it does not flash the left one does. If I turn the headlights off both work as they are suppose to. Has anyone else run into this problem?
Thank You
bcox76 is offline
post #110 of 110 Old 06-25-2017, 11:49 AM
samiam1967
those look great on the black Jeep great contrast.
samiam1967 is offline
2" Round LED Reverse Light bywaters TJ Wrangler Technical Forum 8 10-09-2008 04:44 PM
Nooooo! Not the round tail light! Brokagain YJ Wrangler Technical Forum 18 11-07-2007 06:05 PM
2003 round tail light installation? jeeperjeff24 TJ Wrangler Technical Forum 7 09-25-2007 02:09 PM
Round Tail light Guys-HELP jeepnmike YJ Wrangler Technical Forum 3 10-17-2006 12:35 PM
