Round 4" LED tail light install! - JeepForum.com
post #1 of 110 Old 12-20-2008, 08:05 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Woo-Hoo!
I am stoked! I did my LED tail light install today, and it's frickin' awesome!
I bought the round 4" LED grommet mount lights from the local Harbor Freight store for $14.99 each (includes wiring pigtail & grommet) and an EL-12 electronic flasher from Napa for $11.99. I stopped by Home Depot for a 2'X4' sheet of thin fiberboard to use as a template.
I unplugged the stock lights from the wiring harness & removed the light housings from the Jeep body. I covered the rear sheet metal of the tub with some heavy fiberglass masking tape I "borrowed" from work to protect the paint while drilling. Behind the light housings are 3 screws (arranged in a triangle formation, 1 to the top, and 2 lower ones) that attach the factory lights to the body, and a large oval shaped hole for the factory wiring to pass through the body. I used the top (centered) screw hole & the large oval hole as reference points for measuring. The left rear light is as low as it can be and not interfere with the gas filler's surrounding trim, and as high as it can be without interfering with the top of the rear wheel wells. The hole required is a 4-1/2" hole and the left one is a tight fit to be high enough to clear the gas filler & wheel well top plate, so I measured the left one first.
I used a 4-1/2" hole saw to cut out a hole in the fiberboard, and used the round cut out disc piece to hold up to the tub & find my center drill point. After drilling out the sheet metal I installed the grommets & wired the lights (green/black stripe factory wire to red brake/turn signal of LED lights, and the solid white factory wire to the black LED park circuit of the LED lights) and popped them in the grommets. They look AWESOME in my opinion!
Now before anyone asks, I have not yet installed my 2" LED side marker lights, and no, I don't have a license plate light or backup lights either. I plan on wiring (through a relay) some low power flood/driving lights up for reverse lights, and I also plan on using a license plate frame with a built in light to address the plate light issue.
Lights off
LED (mine) & stock (wife's) park lights
LED (mine) & stock (wife's) brake lights
All in all, for under $50 & less than 1 hour it was a really great mod (I think!) that I had been wanting to do for a long time.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #2 of 110 Old 12-20-2008, 08:11 PM
Brads_nky_yj
same lights I have man. They are great and are plenty bright enough. Now post some pics!!! lol
93 YJ - SOLD
Brads_nky_yj is offline
post #3 of 110 Old 12-20-2008, 08:17 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
I was a bit afraid that the 10 LED version wouldn't be bright enough, but they are a LOT brighter than my OEM lights ever were!
Mean Max is offline
post #4 of 110 Old 12-20-2008, 08:51 PM
1bad92yj
I wanna see some pics, thinkin about doing this myself.
1bad92yj is offline
post #5 of 110 Old 12-20-2008, 09:38 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
i used a tag light from wal mart, they sell them for trailers.
also used a rectangular 55w light for the backup light wired through a relay. the swithc feed was from the stock reverse light circuit.
cheapo fixes.
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #6 of 110 Old 12-20-2008, 10:02 PM
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
i cant wait to see some pics... i was thinking about doing this for a while then i decided to just stick with my custom tail lights... seeing that i have seen no one with them. xD.. (600 post haha)
Thomas
-1987 YJ
Tompatt is offline
post #7 of 110 Old 12-20-2008, 11:04 PM
timatoe
timatoe's Avatar
I used the same ones too.
I did just buy some new ones though 43 LED I think from a truck stop same price.
timatoe is offline
post #8 of 110 Old 12-21-2008, 01:34 AM
spiicytuna
Got you a picture with them lit up ... i.e. with someone pressing the brake pedal?
spiicytuna is offline
post #9 of 110 Old 12-21-2008, 03:53 AM
timatoe
timatoe's Avatar
Nope, I'd get one but it's buried in snow right now. I bet Max will get one though.
timatoe is offline
post #10 of 110 Old 12-21-2008, 08:47 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
I used the iBoat (SeaSense) flange mount tail lights. They are only $5 more per light, and have a lot more LEDs. I much prefer the look of the array instead of a couple LEDs.
Took the picture at dusk, so its kinda dark.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #11 of 110 Old 12-21-2008, 08:55 AM
yjcrawlr
Napa had some high count ones on sale for 19.99 other wise I would have had the harbor freight ones.
90 YJ 102 in wb stretch, SOA, dana 60, 14 bolt welded,4.56s, 37in Parnelli jones dirt grips, currie twin stick dana 300, york oba, tractor link traction bar, full custom armor,poison spyder tube fenders, 95Cherokee High Output 4.0
2014 JKU, modified Rubicon Rails, RC stubby with warn 8000m, 2" leveling springs and OME trim spacers, Superchips Flashcal, Spidertrax wheel spacers, rubi shocks, and Lots more mods soon!!!
yjcrawlr is offline
post #12 of 110 Old 12-21-2008, 10:21 AM
wranglerswrock
mean max
PICS OR IT DIDNT HAPPEN!!
wranglerswrock is offline
post #13 of 110 Old 12-21-2008, 04:28 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Pics added to first post.
Mean Max is offline
post #14 of 110 Old 12-21-2008, 04:32 PM
Brandon_YJ
1987 YJ Wrangler
Looks like utter garbage!
EDIT:
Yes, that was a joke.
No, I knew Max got it, this EDIT is for the rest of you.
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using
in a (text only)
. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused
to see how I view the forum.
Brandon_YJ is offline
post #15 of 110 Old 12-21-2008, 04:32 PM
choeyreplied
are these street legal?
choeyreplied is offline
2" Round LED Reverse Light bywaters TJ Wrangler Technical Forum 8 10-09-2008 04:44 PM
Nooooo! Not the round tail light! Brokagain YJ Wrangler Technical Forum 18 11-07-2007 06:05 PM
2003 round tail light installation? jeeperjeff24 TJ Wrangler Technical Forum 7 09-25-2007 02:09 PM
Round Tail light Guys-HELP jeepnmike YJ Wrangler Technical Forum 3 10-17-2006 12:35 PM
