Quantcast rough ride after 4" rubicon express lift - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > rough ride after 4" rubicon express lift
Old 04-06-2008, 06:16 PM   #1
sasquachYJ
I installed a rubicon express 4" lift and its been about a month now. I thought the ride would get better when the new lift worn in, but it has not at all. The ride is horrible! is anyone elses jeep that bad after their lift? Also, would greasables shackles make the ride better?
Thanks
stock 99 for now
sasquachYJ is offline   Reply With Quote
Old 04-06-2008, 06:27 PM   #2
flkeysff
I can't say about the lift but I can say greasable shackles improved my ride alot!
85 CJ7, shown in pic, getting a new pita body and way too much money spent on making it look pretty!
88 YJ (bought for my daughter) still my project!
90 YJ (bought for me) gutted everything going to start from the ground up! Plans include new interior, roll cage, dash, 5.0l 302, 8.8 rear, SOA lift, stainless lines and any other thing I can spend money on! At least until my wife finds out!!!
flkeysff is offline   Reply With Quote
Old 04-06-2008, 06:31 PM   #3
1992_Wrangler
What size tires are you running and how much air pressure do you run in them? I have the same lift and run 35's at about 25 psi, I think it rides well all things considered.
They are the black shoes, white helmets and plain uniforms of one of Americas most successful programs. They are heroes, they are winners, they are Penn State football.
1992_Wrangler is offline   Reply With Quote
Old 04-06-2008, 06:33 PM   #4
93jeepREDSOX
I notice more of the bumps, but the ride isn't that bad. Check your psi in your tire.
1993 YJ 4" RE lift, 1/2" shackles, AA SYE Kit, 33x12.50 Trxus M/T, Warn bumbers front and rear, Warn M8000 winch, 4 Hella fog lights, Magnaflow cat, flowmaster muffler with no tailpipe, herced tub, tj flares
HOW BOUT THEM REDSOX
My Rigrator score 535RRv1.0 BOA 25
93jeepREDSOX is offline   Reply With Quote
Old 04-06-2008, 06:38 PM   #5
sasquachYJ
im runnin 31" bfg at's with about 30 psi
stock 99 for now
Old 04-06-2008, 07:16 PM   #6
tuckinauster
Yes, also check the tightness of the shackle bolts as well as the frame eye bolts. I run shackle bolts at ~50 ft/lbs and frame bolts 95ish.
Sniper Central
Originally Posted by P.J. O'rouke
"The Jeep is a manly device. And a womanly device. An American device. It’s a fitting instrument to transport the free people of a free nation with the respect to which we are entitled and the dignity that we deserve."
tuckinauster is offline   Reply With Quote
Old 04-06-2008, 07:21 PM   #7
Axl Jack
A taller spring is going to make the ride a little rougher over a stock spring. Thats what you sacrifice to stuff bigger meats under your fenders. If you wanted a smooth ride with a moderate lift you should have gotten 2" BDS or 2.5" OME.
That being said, maybe going to a gas charged shock instead of hydrolic might help.
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline   Reply With Quote
Old 04-06-2008, 10:28 PM   #8
beer thirty
the shocks that come with that kit suck balls. i had that on my old YJ, and compared to the 4.5" XD kit I have now, it rode horribly. i've also heard their regular springs are made by the same ppl that make the pro-comp springs
beer thirty is offline   Reply With Quote
Old 04-06-2008, 10:58 PM   #9
iwishihad1
you can try changing out shocks, but i think your stuck with what you got for the most part. you might be able to smooth it out a little but those springs are pretty hard. i had a friend who installed a set on his jeep. i wouldn't be able to drive that jeep everyday for sure. and this is coming from somebody running AALs in a cherokee, and daily drives a Yj with 10 inches of lift and 36s.
his springs have gotten a little smother after a year, but id still consider them pretty harsh. me and friend just installed a 4 inch RC kit, and i think it rides much better. i dont think the RE kit flexes very well either because of the stiffness of the springs
[CENTER]1995 fire red XJ, new 4.0, ARB safari snorkel, sye, front DS, aussie locked 8.8 5:13s 38 SXs, trussed/locked 44 front, hydro assist, DOM steering/COLOR]
YJ. 91 body, body off resto, crate chevy 350, 700r tranny, 2 inch springs, SOA, ford 9 rear, dana 44 front, both detroits, cage, 4:88s, and 36X14.50s. strictly street queen
iwishihad1 is offline   Reply With Quote
Old 04-08-2008, 12:57 PM   #10
95 Lowbuck
Re Std 4"
I have the same lift and it road harsh.
The stock shackles are really not made for that
type of spring bushing.
Buy some greasable aftermarket shackles and only
tighten them to 50-60 ft lbs and you will notice
a big difference.
Also take off the F&R track bars.
95 Lowbuck is offline   Reply With Quote
Old 04-08-2008, 01:53 PM   #11
warregl
Not exactly a ringing endorsement...
____________________________
[I]'54 Willys - my first vehicle
'75 CJ5 - the quail hound
'77 CJ7 (V8) - lost to youthful enthusiasm
’95 YJ – some days I actually miss my 4 angry squirrels
’03 Rubicon – seems too nice to be a Jeep, until the pavement ends…[/I]
warregl is offline   Reply With Quote
Old 07-01-2009, 09:22 PM   #12
ddor
1994 XJ Cherokee
i own a 94 yj, 4 in. RE lift, OE shackles, doetsch tech shocks. i have absolutley NO FLEX and when i hit a bump i can get air. RE tech said to raise the truck up off the ground and loosen all spring bolts, set it back down and snug everything back up. i tried this and it didn't help. i then tried removing the third leaf spring from the bottom( the one that is really thick) and all that did was drop me an inch. no improvement in flex. im now considering the skyjacker 6in. mono-leaf kit
ddor is offline   Reply With Quote
Old 07-01-2009, 11:52 PM   #13
hanshunter
hanshunter's Avatar
I had a whole different animal but with the same issue. I bought my 95'
and it had a 2.5" Pro Comp lift. I thought my teeth would bounce out of my head! Removed the front and rear trac bars and it seemed to help some. Then installed a set of currie booms and you would not believe how much better it rides now! Think I can air up the tires a bit now and get a little better mileage! LOL! Try some greaseable booms!
hanshunter is offline   Reply With Quote
Old 07-02-2009, 07:26 AM   #14
YJPirate
Remove the track bars and see how it rides.
Edit: I just saw you have an XJ. Guess that wont work.
YJPirate is offline   Reply With Quote
Old 09-23-2009, 10:56 PM   #15
ddor
1994 XJ Cherokee
i have both a 94 xj and a 94 yj.both with the same amount of lift. yj's really should have come with front coils and spring over axle rears but maybe thats why im not an engineer
Glock Forum
