Rough Idle 91 YJ 6 cyl - JeepForum.com
post #1 of 5 Old 04-04-2004, 07:25 PM Thread Starter
Kmg3356
I just tuned up my 91 YJ fuel injected 6 cyl ,cap rotor, wires, plugs ( gapped at .035), fuel fllter and wires. Now the engine has a rough idle. the wires are in the correct order and off of idle it runs great. I pulled each wire off with the motor running and they seem to all be working. The fuel filter i took out had the arrow the wrong way and i put the replacement on the right way.... There are no vaccuum leaks that i can see. I also replaced the air filter. and added fuel injector cleaner. there is a little blow by oil on the filter .. What could i have screwed up with the tune up ? Thanks in advance !! Keith
Kmg3356 is offline
post #2 of 5 Old 04-05-2004, 06:30 AM
Scurv
Scurv's Avatar
Look here
http://home.sprynet.com/~dale02/idle.htm
RETIRED USAF MEDIC
89 YJ, 258 I6, 5 Speed/Manual, Red, 30x9.50 GSA/Gambler,Air Force Jeep Club Member #31
Red Jeep Club Member #284
Scurv is offline
post #3 of 5 Old 04-05-2004, 09:11 AM
hambubba
So he needs to put a carburator on it?
hambubba is offline
post #4 of 5 Old 04-05-2004, 10:00 AM
Birdawg
Birdawg's Avatar
IF you have oil on your air filter, the rear ccv may be plugged. It is the rear vacuum hose fiting that is located on the top rear of the valve cover. The vac line goes from there to a nipple on the intake.If the ccv or the hose is plugged it would cause a rough idle. Pull the vac line and turn the ccv in the valve cover 1/4 turn counter clock wise to remove it for cleanning. Should be able to blow through the ccv and the hose.
Good Luck
Peter
1992 YJ 4.0 Liter HO I6
Sitting on a Rock in the Bay
Air Restrictor & Chicken Bones Gone,20 Gal.Gas Tank :) Audiovox CD Sound Bar, Front Tow Hooks. Hard & Soft
Tops. 31" x 10 1/2" x 15" Coopers
Sumer Projects:2 1/2" Rubicon Express.(Done) New Metalic Paint.(Done)
31" Tires (Done), Bed Liner. Dome Light for Soft Top
Blue Jeep Member #15
Birdawg is offline
post #5 of 5 Old 04-09-2004, 05:57 PM Thread Starter
Kmg3356
Rough Idle Solved
It turned out to be a bad autolite (brand new ) plug.. thanks for all your help... Keith
Kmg3356 is offline
Idle Air Controller - Trying to Clean for Rough Idle - Need Help JBWood05TJ TJ Wrangler Technical Forum 21 08-24-2008 06:40 AM
AC on idle rough coastiejohn YJ Wrangler Technical Forum 4 08-19-2007 08:14 PM
Rough Idle themajor YJ Wrangler Technical Forum 3 08-26-2004 08:48 PM
Carter BBD fix for No Idle or Rough Idle ScotZ YJ Wrangler Technical Forum 0 03-26-2003 09:26 PM
rough idle jaykump TJ Wrangler Technical Forum 5 11-19-2002 07:21 AM
