Rough Idle - Page 2 - JeepForum.com
 3Likes
post #16 of 19 Old 03-30-2017, 10:09 AM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
The main reason I put one in, is when I was at 8000', trying to climb rocks very slowly, at around 500 RPM, it would overheat. Not a problem anymore. I had no other problems with the clutch fan.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #17 of 19 Old 03-31-2017, 10:55 AM
mike134
can't really argue with results.
mike134 is offline
post #18 of 19 Old 03-31-2017, 11:51 AM
Que89YJ
If you get miles on the jeep the hotter spark helps get better ignition and a more complete burn across a wider range of fuel/air mix. Plus it simplifies the ignition system. Power to the distributor and plug wires out. Much cleaner with way less to go wrong.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #19 of 19 Old 03-31-2017, 03:02 PM
Theman1945
Theman1945's Avatar
Originally Posted by mike134 View Post
in which case people notice a "HuGe HoRsEPoWeRZZ GAINZ!!!"
Well done sir
1988 YJ OKSJC
Theman1945 is offline
idle , rough idle , vibrations
