Rough Idle 4.0 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Rough Idle 4.0
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 02-08-2003, 11:56 PM   #1
ErikJordan
Pimp Hand
ErikJordan's Avatar
Rough Idle 4.0
this jeep iodles rough, but when you give it gas bringing the rpms over 1000 it smoothes right out.
i put new plugs, cap, rotor, fuel cleaner. any suggestions?
where can i get the computer read for codes without paying an arm and a leg? is there a way to get the codes from the computer without having the expensive equipment?
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline   Reply With Quote
Unread 02-09-2003, 12:04 AM   #2
evilpsych
did you reset the computer after installing all that? (disconnecting the battery, then restarting the vehicle and letting it idle for 5-20 minutes..)
the way to pull codes is turn the key on-off 3 times.. then the engine check light with flash codes.. and you can read the codes outta your haynes manual which lists them..
rough idle is one of several things.. plugs, cap, rotor, wires, throttle position sensor, crankshaft position sensor, or O2 sensor..
since you've already replaced the cap, rotor, and plugs.. i'd look at the other 4.. hopefully it's something simple like O2 sensor, wires, or the TPS..
it's my understanding that the CPS is a pain to replace..
Awwwwwwwwwwww... So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline   Reply With Quote
Unread 02-09-2003, 12:13 AM   #3
habman
Check for a code reader on http://www.summitracing.com someone told me they have a reasonable reader. I hate computer controlled engines for just that reason. There are so many things that can cause a rough idle from a bad O2 sensor, a crank sensor, the throttle position sensor, throttle body... the list goes on and on.
The only way to figre it out, without swapping a lot of parts, is to get the codes read.
HABMAN
PURPLE JEEP CLUB MEMBER #0
1977 CJ-7 with all stainless hardware, fittings. hoses and lines.
Glass body in fresh Imron Medium Royal Plum Purple with bright freaking yellow interior.
New Tuffy Stereo Security Console
New BesTop Supertop
Full 8 point cage with frame ties.
33 X 12.50 Yokohama AT + II, I dumped my FRENCH made BFG's
400cid Chevy SB and 350 Turbo trans
All fresh from an off frame resto summer of 02, but is it ever really finished?
habman is offline   Reply With Quote
