Rough country suspension add-a-leaf - JeepForum.com
post #1 of 5 Old 06-05-2011, 08:11 AM Thread Starter
Mohsen95
Hi all
I have a 95 wrangler with 4” suspension lift and 3” body lift, all from rough country. 35/12.50/15 wheels with 2.5 motor.
My problem is that when I am offroading, I tend to cause the rear tires rub on the body and at some point, I am sure the tires will be ruined.
I can’t afford to get 6” or 8” lift right now, so I am was thinking of getting the SUSPENSION ADD-A-LEAF from rough country, but I am not sure if this recommended by the experts or is there any gotchas that I need to be aware of.
Mohsen95 is offline
post #2 of 5 Old 06-05-2011, 08:16 AM
hesserdude07
Originally Posted by Mohsen95 View Post
Hi all
Buy a set of Daystar poly extended bump stops from Quadratec... I had the same problem. Got sick of slicing my rear tires....
1993 Silver YJ. SBC 300hp. 700r4. NP231 hybrid. 35" Mud Terrains. 7" Toyota Basterd packs. 8.8 Welded. D30 loc-rite. 1" body lift. 4" LED tails. Custom bumpers. Warn M8000. Hella's. (Trail rig)
hesserdude07 is offline
post #3 of 5 Old 06-05-2011, 11:35 AM Thread Starter
Mohsen95
you are absolutely correct sir, because and as a matter fact, I don't have any bump stops at all, which explains the problem I am having.
I'll go ahead and get the ones you recommened and post later to let you know how it went.
Thanks a lot.
Mohsen95 is offline
post #4 of 5 Old 06-05-2011, 02:37 PM
hesserdude07
No problem.. i love the ones i got from them... And they have saved me 100s of times. Mine hit on my 8.8 perfect, well did before i went to a bigger lift.
post #5 of 5 Old 06-05-2011, 02:52 PM
TheNewbie
+1, you need bump stops. Going with 6" lift spring will NOT STOP YOUR TIRES FROM RUBBING. You can still flex the springs into a flat shape. As a matter of fact, with the right bump stops you could go down to a 2.5" lift spring and still run 35's with that body lift. I doubt that you will even need extended bump stops with a 3" BL. Just get some bump stops period. Bottom out your suspension to find out how much you need to limit it. Then get the proper bump stops. Going too long will limit your flex, but going too short will allow the tires to hit the body.
1995 YJ 2.5 - 4” RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
Rough Country leaf springs starting to rust MWguy101 YJ Wrangler Technical Forum 6 04-14-2010 08:13 PM
how to install a rough country 2" add a leaf in a yj luis92yj YJ Wrangler Technical Forum 5 02-23-2010 03:36 PM
rough country leaf springs sag? Black91YJ YJ Wrangler Technical Forum 9 02-25-2007 03:34 PM
Rough Country leaf springs? 1stJeepyj YJ Wrangler Technical Forum 4 05-13-2006 07:07 PM
Rough Country Add-a-Leaf?????? PoorFool YJ Wrangler Technical Forum 3 04-08-2002 03:32 PM
