Rough Country Spring Over Perches - JeepForum.com
post #1 of 1 Old 08-06-2012, 11:09 AM Thread Starter
n9oig
Rough Country spring perches are drilled out to 5/8. 3/8 center bolts are 1/2.
I know the center pins locate the axle for center and to keep it from moving.
Yes once the ubolts are tightened down it shouldn't move but it will hitting bumps rocks can move it back or forward which will through off the alignment.
Darin at Rough Country says thats normal. The factory doesn't have a sloppy hole.
Is there special center pins with 3/8 threads but 5/8 head?
88 Jeep Wrangler
95 Jeep Wrangler
SE Wisconsin
n9oig is offline
Update on my Rough Country spring sag unlucky YJ Wrangler Technical Forum 3 06-21-2011 10:30 PM
Rough country coil spring fail.... jezow2010 TJ Wrangler Technical Forum 13 06-20-2011 06:49 PM
Rough country 2.5" coil spring kit: what else did you need? shiftless06 Wrangler General Discussion 10 06-20-2009 06:26 AM
rough country spring break officialvin YJ Wrangler Technical Forum 13 06-19-2007 04:56 PM
Rough Country Spring Specs hillbillyyj YJ Wrangler Technical Forum 2 02-23-2007 01:44 PM
