Rough Country New and improved!!!!! - Page 161 - JeepForum.com
post #2401 of 3152 Old 09-08-2009, 11:27 AM
1998zj
You call lots of bent and saggy springs a little issue?
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #2402 of 3152 Old 09-09-2009, 05:26 PM
ROADDOG516
Day 1 of install went pretty smooth got everything on front done, took so long because everything was stock and rusted on or fallen off.. uestion can anyone shoot me a pic of there brake relocation brackets? The manual is pretty vague and leaves alot of open ends which I hope Ive done correct. And could anyone tell me which bushings they used on the ttop of the front shock mounts thru the frame mount...Thanx
YJ=THE LAST REAL JEEP!
1966 Willys
1993 YJ
2013 JKU Sahara
ROADDOG516 is offline
post #2403 of 3152 Old 09-10-2009, 07:56 AM
CTJeepin
1987 YJ Wrangler
Anyone have any luck getting in contact with this Ryan guy? I emailed him about a month ago and got no response. I also called twice and wasn't able to get in contact with him. I'm on the fence as to whether or not I should go with their lift and have some questions for him regarding these "new" springs that they're using now. Their lack of customer service isn't exactly helping their cause.
CTJeepin is offline
post #2404 of 3152 Old 09-10-2009, 08:14 AM
1997_Sport
Call up Jeff the tj RC guy. He is known to answer his callls. haha
1997_Sport is offline
post #2405 of 3152 Old 09-10-2009, 09:01 AM
Rohdawg
I had a little luck by "chatting online" with them.
If you sit on their website long enough a chat box pops up and than you got 'em! Ask all the questions you want. They answered all of mine for the most part.
89 YJ, 4.2L I6 automatic, 2.5" RC lift, 1" RC Boomerang Shackles, 33x12.5 Trxus STS, Trac bars are in the blue trash can
Rohdawg is offline
post #2406 of 3152 Old 09-10-2009, 09:04 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Originally Posted by MosinMe View Post
If I had somebody busting my balls over every little issue that they had with a $450 lift kit I probably would too.
Is this directed at me???
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #2407 of 3152 Old 09-10-2009, 09:16 AM
Rohdawg
Don't feel too bad. Mine took me a week working on it 3 to 4 hours a day. Mostly because I was by myself working in less than optimium conditions. But alot of it had to do with the fact that everything on my jeep was 20 year old stock parts that were nearly impossible to remove. Except the leaf springs....those shattered with one whack of the 5lb sledge. QUICK AND EASY!
Rohdawg is offline
post #2408 of 3152 Old 09-10-2009, 12:14 PM
ROADDOG516
Ok ALL DONE with the install!!! In review kit arrived fast, but was missing several nuts and fastners. Even though I bought the replacement spring bolt kit, it too was missing nuts, no big deal had to go buy them. Quality of major parts seems pretty good. The instructions are very vague and leave a lot up to interpertation, but thankfully after a few screw ups it wasnt to hard to figure out. As far as customer service for the help line I must of caught them on a bad day because first try put on hold then hung up on, second try had some very confrontational rep who said I wasnt missing anything (but was wrong as I double/triple checked, and third try basically got no info other than brief description from manual. Overall I would do it again and the finished product looks killer. The bonus is that I didnt know I had so much else to upgrade (ex. brake lines all rusted to crap, and brake drums worn out). So as a novice I would recommend this kit to anyone like myself looking for a good lift for the cash and for recreational use. Just be prepared with alot of PB and dont start on a weekend when you cant find backup parts. Also this is my opinion without an actual road test----have to finish up the brakes and get tires so I will give my 2cents after a month of use..
1966 Willys
1993 YJ
2013 JKU Sahara
post #2409 of 3152 Old 09-10-2009, 02:14 PM
basestealer12
i got my rc 4" about 2 years ago and havent noticed any sagging at all so far. and it only took me about 7 hours to install
basestealer12 is offline
post #2410 of 3152 Old 09-20-2009, 07:12 AM
spshultz
1987 YJ Wrangler
I have a couple of questions. My son and I are in the middle of installing the 2.5" lift kit.
Last night we managed to get the old rear springs out and the new ones in but have noticed two issues so far:
1. Not enough nylock nuts for the u-bolts. I have 8 u-bolts and only 8 nylock nuts and washers. How come they don't give you 16 nuts for the u-bolts?
2. I noticed that a bolt goes through the spring pack to hold it together. Then there is a nut on that bolt on the bottom of the spring pack that holds the pack together. When I put the u-bolts and spring pack "plate" on, the plate contacts the nut on the bottom of the pack. If I were to tighten down the u-bolt nuts completely there would be about a 1/4" gap between the u-bolt plate and the bottom of the spring pack because of this nut. Do I have to take this nut off? Wouldn't that cause the spring pack to fall apart? I'm sorry it's kind of hard to explain without pictures but on the old springs, the u-bolt plate butted firmly up against the bottom of the spring pack. With the new springs this isn't going to happen.
So far the shackle bolts were easy. It's the spring-to-frame bolts that we had to cut off with a 4.5" cutting wheel. Yowza they were on there good!
spshultz is offline
post #2411 of 3152 Old 09-20-2009, 07:45 AM
rustywrangler
1) check the other bags for the front, my 2.5 kit had extra nuts in the others.
2) I ran in to this exact problem. I used my air impact gun to "press" that nut into the plate hole. Personally, what I would do, is drill the spring plate hole a bit bigger for that nut. You cannot remove it, because, as you said, the spring pack would come apart.
post #2412 of 3152 Old 09-20-2009, 07:55 AM
Djsthe1
I don't think that the nylock nuts go on the U-bolts. Did you buy the new hardware pack for the springs? The spring bolts should use the nylock nuts and I believe that the U-bolts get lock washers and normal nuts. As for the spring packs, you might have to drill out your U-bolt plate so that the nut sits inside of it. the holds it center just like if you install shim the bolt in the springs will hold the shim centered.
Hope this helps.
Djsthe1 is offline
post #2413 of 3152 Old 09-20-2009, 09:42 AM
spshultz
1987 YJ Wrangler
Thanks guys! I checked all the boxes and no extra nuts. So I went to Lowes this morning and got some more nuts and washers. $20 worth of nuts and washers and we are back in business. We are headed out to finish it. Hopefully we can get it done before the rain starts.
spshultz is offline
post #2414 of 3152 Old 09-20-2009, 06:30 PM
spshultz
1987 YJ Wrangler
And we're done! But.... the darned brake lines are just about tight and the drive shaft vibrates really bad. I can't go above 30 mph. I did not expect to need extended brake lines with a 2.5" lift. Anyway, this thing sits muuuuuch higher. The 235's on it now look tiny. I am really excited. More so than my son I think. Ha!
spshultz is offline
post #2415 of 3152 Old 09-20-2009, 08:22 PM
Rohdawg
I had to put a transfer case drop kit on mine. The guys at RC we're surprised I needed it but mine vibrated right at 30 mph also. The tc drop fixed all that though.
Rohdawg is offline
lift , review , rough country , suspension , YJ
ROUGH COUNTRY LIFT = REALLY ROUGH RIDE? Why? pjleslie03 TJ Wrangler Technical Forum 32 01-02-2011 02:02 PM
to rough country or not to rough country thats the question dw9301998 YJ Wrangler Technical Forum 22 10-07-2009 06:46 PM
4" X Series Rough Country = Too Rough..Help nobody2u TJ Wrangler Technical Forum 21 07-29-2009 11:06 PM
rough country bar pin eliminator rough ride after? emahan01 TJ Wrangler Technical Forum 3 02-21-2009 10:05 PM
Rough Country or Tuff Country 2.5" Lift? bballard1227 YJ Wrangler Technical Forum 7 09-23-2008 07:55 PM
