Quantcast Rough Country New and improved!!!!! - Page 13 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Rough Country New and improved!!!!!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 03-25-2008, 08:48 AM   #181
Rough Country
Vendor
Rough Country's Avatar
Originally Posted by RedneckYJ View Post
My sleeves were missized also. I had to run an old shackle bolt in a couple of the frame rail mounts to mount the leaf springs. Just as you stated though. Would be a great kit with a little more QC. HINT HINT RC: Start checking what is leaving your doors a little closer. Its the small stuff that costs you business. Just my 2 cents though.
Robbie
This is being addressed as we speak. Thank you for bringing this to my attention.
ans@roughcountry.com
ALL JEEP FORUM MEMBERS GET 10% OFF CALL RYAN AT 1-800-222-7023 EXT 123!!
Rough Country is offline   Reply With Quote
Old 03-25-2008, 09:00 AM   #182
vfrpilot
Rough......
Forgive me... but I didn't get an answer ?!?!
scroll up for my comment/question
TIA
01 TJ SPORT - 4.0, 4" Lift on 16" MOABS /SSTs
Post count CUT from over 1400 to 940 on 1/30/09 - What'd I do ?
/l ,[___],
l--L-⌐OlllllllO-
Criminals thrive on society's indulgence in tolerance
vfrpilot is offline   Reply With Quote
Old 03-25-2008, 09:00 AM   #183
tuckinauster
Robbie
dont know if you noticed or not, but the kit comes with two different sizes of bushings. the bigger bushings are for the frame mounts, and the smaller ones are for the shackles. this confused me when i first installed the lift, after i realized that there were different size bushings life was good again.
Sniper Central
Originally Posted by P.J. O'rouke
"The Jeep is a manly device. And a womanly device. An American device. It’s a fitting instrument to transport the free people of a free nation with the respect to which we are entitled and the dignity that we deserve."
tuckinauster is offline   Reply With Quote
Old 03-25-2008, 09:19 AM   #184
lurkeryj
1997 XJ Cherokee
yeah it wasnt the outside diameter, it was the inside diameter that was the problem. the bolts wouldnt fit through the sleeves
lurkeryj is offline   Reply With Quote
Old 03-25-2008, 09:37 AM   #185
Rough Country
Vendor
Originally Posted by vfrpilot View Post
My current concerns: I'm watching for sag and/or uneven tilt... I'm a bit concerned as I write this.....
MY kit was professionally installed as well as ordered through [the installer].
I paid the extra for the pro install to ensure warranty accountability; so my question to RoughCountry....
I shouldn't have ANY problems with regard to replacements IF I need, right?
I am your direct link to the manufacture as long as you have proof you are the original purchaser I will take care of you. I hope that was the question you wanted answered sorry I missed it.
Old 03-25-2008, 09:39 AM   #186
Brads_nky_yj
Rough Country gets at least a frikin A++ in Customer Service from just what I have read in this thread. Good job RC!
Brads_nky_yj is offline   Reply With Quote
Old 03-25-2008, 09:52 AM   #187
vfrpilot
Yea, that was the one I was referring to
"I" had it installed Rough... as I said in the post.
What kind of proof? My install receipt I guess right? - Since the shop purchased/installed.....
/l ,[___],
l--L-⌐OlllllllO-
Old 03-25-2008, 10:16 AM   #188
Rough Country
Vendor
Yup that will work. If the case arises that you need warranty work the replacement parts will be sent to them unless authorized by the shop (since they were the actual purchaser from us directly.) Bottom line......You will get taken care of..PERIOD.
Old 03-25-2008, 10:26 AM   #189
91yjjeep
Rough Country Kits
I have used Rough Country kits for many years and I can tell you guys from first hand experience, that the Rough Country kits are by far the best that I have found for the money and for the quality of the components in the kits. I have used them on the streets and I have bashed them offroad and I have never had a problem with the function or the quality of their kits. As far as the ride, I have riden and driven many different off road rigs and the flex and comfort of the springs are second to none. I realize that everyone has a preference, but from my experiences those guys are top notch!!! I will never use anyone else for my road rigs or my trail beaters.
FYI......You can also overtighten the spring bolts!! So be careful when tightening the bolts because that will make your ride a little rougher due to the poly bushings.
I will also say this. Who do you see more of actually on the trail with their rigs. The last couple of off road events that I have been to, the guys from Rough Country have been there with their rigs. They were not just sitting around, they were on the trail with their rigs. I have not seen another company that takes such an interest in our off road lifestyle. IF you have a problem, these guys listen. So we all need to give them some props for having the b@!!s to ask us what we think as offroaders.
Thanks guys for listening to us.
91yjjeep is offline   Reply With Quote
Old 03-25-2008, 11:22 AM   #190
tuckinauster
i know that, there is two different sizes of bushings with different inside diameters. all of the outside diameters are the same.
Sniper Central
Old 03-25-2008, 11:25 AM   #191
lurkeryj
1997 XJ Cherokee
yeah i was just tryin to say that using the smaller bolt with the smaller sleeve and the larger bolt with the larger sleeve, both sleeves were to tight inside.
Old 03-25-2008, 11:28 AM   #192
tuckinauster
ahh, that makes sense now... when i did my lift i tried shoving the big bolt through the small bushing at first
Sniper Central
Old 03-25-2008, 11:47 AM   #193
swa240z
Just for clarification, the sleeves for both the frame side and the shackle side have the same outside diameter. The frame sleeve has a larger inside diameter than the shackle sleeve. If you try to use a shackle sleeve on the frame end, the bolt will not fit.
Yellow 2000 TJ, 4.0L, NV3550, 3.73 gears. 4" RC X-series lift, 33x12.50x16 MT MTZ's on 16x10 MT Classic Bead Locks. Bumpers, winch, axles and gears coming soon.
./l ,[_\_\ ],
l---L –OlllllllO-
()_) ()_)--o-)_)
swa240z is offline   Reply With Quote
Old 03-25-2008, 11:57 AM   #194
lurkeryj
1997 XJ Cherokee
yeah i know. the sleeves were to small on the inside when being used on the correct end of the leaf with the correct bolt.
Old 03-25-2008, 01:59 PM   #195
Corpse Kid
I had to cut my bolts off I am getting ready to buy new ones. Your kits came with them?
Corpse Kid is offline   Reply With Quote
lift, review, rough country, suspension, YJ
Glock Forum
