Rough Country Lift Questions - JeepForum.com
post #1 of 10 Old 01-07-2012, 05:28 PM Thread Starter
jeeprookie15
1987 YJ Wrangler
I have this lift kit for my yj. http://www.roughcountry.com/jeep_yj_4.html
It comes with some metal sleeves and i was just wondering where all of these went. I have four left over and i dont know where they could go. I put one in the bottom of every shock where the bolt goes in. Ive put one on the rear track bar. I think thats all ive used. Any ideas of where they go? Thanks!
jeeprookie15 is offline
post #2 of 10 Old 01-07-2012, 05:34 PM
schaef89
If I'm thinking about the same sleeves they should go inside the spring bushings. They're meant as a buffer between the spring bolt and the bushings
schaef89 is offline
post #3 of 10 Old 01-07-2012, 05:40 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Check pg #2 here for where the sleeves go: http://www.roughcountry.com/install/1620N2.pdf
Joe Dillard is offline
post #4 of 10 Old 01-07-2012, 05:56 PM Thread Starter
jeeprookie15
1987 YJ Wrangler
Thanks so much! schaef98, do the sleeves go in where the spring meets the shackles or where the spring meets the frame mount?
post #5 of 10 Old 01-07-2012, 06:34 PM
stockyj
my leafs came with the sleeves with the bushings already.. weird.
stockyj is offline
post #6 of 10 Old 01-07-2012, 06:37 PM
stockyj
or Front Sway Bar Links
2-12mm x 65mm Bolts
2-Flat Washers
2-12mm Flange Lock Nut
2-Upper Sleeves
1620Bag2:
For Fr and Rear Shocks
4-Shock Sleeves
stockyj is offline
post #7 of 10 Old 01-07-2012, 06:38 PM
soonermatt
(I'm not the one you asked but have the same lift) both the shackle to spring and spring to frame will require that sleeve. The idea is the you torque it down so much the the bushing rubs against the sleeve rather than screw to hanger or shackle.
In their absence you would tear through the bushing with the screw. Proper torque would damage the hanger and possibly the shackle too.
soonermatt is offline
post #8 of 10 Old 01-07-2012, 06:42 PM Thread Starter
jeeprookie15
1987 YJ Wrangler
Why did my kit have so many sleeves? I have four left over when the instructions say i only need 2 for the sway bars. Oh and by the way, why dont the instructions say that i need sleeves in the springs, or do they even need them??
post #9 of 10 Old 01-07-2012, 07:25 PM
soonermatt
I do not believe that a screw should contact rubber in any part of your suspension or kit. They should be separated by those sleeves. This includes shocks, track bars, spring hangers, steering dampeners, shackles, body mounts and so on.
post #10 of 10 Old 01-08-2012, 01:51 AM
SandyMushYJ
True. My RC lift had sleeves for every bolt--both ends of the springs, which are two different sizes, and frame mounts on both ends. For the springs you have to size them with the bolt for each end. If you have poly or rubber bushings with no metal sleeves in them, more than one thing will go wrong. Soon.
'95 YJ, 2.5L, AX-5, RC 2.5", 31" Pro Comp MT's
SandyMushYJ is offline
country , kit , lift , rough , YJ
Rough Country 2.5 Inch lift questions BadPirate JK Wrangler Technical Forum 10 03-14-2011 10:14 AM
4" Rough Country Lift questions cyberpvnk JK Wrangler Technical Forum 4 04-22-2009 09:59 AM
Have questions on 4" Rough country lift ZeroG TJ Wrangler Technical Forum 9 12-19-2008 03:53 PM
Rough Country 4 inch Lift Questions 77eagle TJ Wrangler Technical Forum 29 10-18-2008 03:16 PM
Rough Country 3" lift Questions Protoxis YJ Wrangler Technical Forum 7 12-13-2002 02:46 PM
