Rough country to BDS question. - Page 8 - JeepForum.com
post #106 of 253 Old 03-13-2014, 09:55 AM Thread Starter
Overhead
Gtwinch started out as okgtwnh but no one could read it. It stands for got winch. Or ok got winch because my first trio out I was a little..... Zealous if you will stating that if anything happened it was ok. Because I had a winch. Didn't need to use it all weekend and then the first time I used it I promptly set the winch on fire as it chewed up its internals. Irony eh?
Carlos14- Gotta love BDS for breakfast.
95yj- Grim-
Friends don't let friends Buy Rough country
Overhead is offline
post #107 of 253 Old 03-13-2014, 01:17 PM
gtg413i
2003 WJ
Gt it nw. What didn't you like about the fab tech springs? They ride like a dump truck? I always assume that is normal for a lifted jeep with cheap shocks.
Brian's Black Betty Build:
gtg413i is offline
post #108 of 253 Old 03-13-2014, 01:43 PM Thread Starter
Overhead
Never run fabtech. Ran rough country. Got pointed twords BDS. It rides smooth and classy on my friends rig and I fell in love. Can't wait to see how mine rides.
95yj- Grim-
Overhead is offline
post #109 of 253 Old 03-14-2014, 10:27 AM Thread Starter
Overhead
meant to go out for more pictures today, totally slept in and now I'm on my way to work instead.
95yj- Grim-
Overhead is offline
post #110 of 253 Old 03-14-2014, 08:11 PM
panaceabeachbum
apologies for repeatidly piling on your thread but it seems like it might be good resource for others down the road going thru what we have with the RC junk.
I have about 300 miles under the jeep with the new BDS springs, I still have the RC shocks, I notice now that the jeep has an actual 3-4 inches of lift that when I lift the jeep by the frame there is less than 1" of travel before the shock is fully extended and greatly limits my droop. What should I do for proper shocks that will allow a the axle to drop more than 1/2", any thoughts appreciated.
OVHD what are you doing about shocks?
panaceabeachbum is offline
post #111 of 253 Old 03-14-2014, 11:58 PM Thread Starter
Overhead
I went a lot over board on shocks. I'll fill you in tomorrow. Please please add to my I HATE ROUGH COUNTRY thread, the more the merrier.
95yj- Grim-
Overhead is offline
post #112 of 253 Old 03-15-2014, 12:16 AM Thread Starter
Overhead
for those of you who don't know what I'm doing shock wise, I'm getting bilsteins.
now you see it.
now you don't
and the new sexy...
adding M.O.R.E rear shock mount extenders, and new lower shock mounts thanks to a broken mount. I'm not sure on travel yet, I'll know final numbers monday.
95yj- Grim-
Overhead is offline
post #113 of 253 Old 03-15-2014, 08:25 AM
panaceabeachbum
Nice!
post #114 of 253 Old 03-15-2014, 08:26 PM
panaceabeachbum
Who makes the hoop in your picture a few pages back and can you share the part # on the bilstien shocks? I am running them on my FJ and they are have been awesome. What are you doing for shocks and mounts on the rear, I would really like some guidance to avoid wasting more money .
post #115 of 253 Old 03-15-2014, 08:34 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
he mentioned the MORE rear extensions. (pic)
as far as you having too short of shocks. take them all off and flex out the jeep. get measurements for full stuff and full droop and order accordingly. generally you want to add 1" to the total length as to not let the shock get tugged on. you also have to make sure the shock isnt what stops you on "full stuff", this can be cured with bumpstops. these are all things I still need to do
-April '14- YJoTM- June '15
The_Goob is online now
post #116 of 253 Old 03-15-2014, 08:43 PM
panaceabeachbum
Yes I saw mention of the rear shock extenders, I covered the rear on mine with a full crossmember and upper mount(ears) from ruff stuff while I had the body off, I was curious about the front shock hoops in the pic in post #90 on page 6 of this thread. I will be testing travel Tomorrow with shocks off, currently the bump stops are handling upper travel but front and rear shocks are severly limiting droop.
post #117 of 253 Old 03-15-2014, 09:03 PM Thread Starter
Overhead
I'll share the part numbers. WFO makes my hoops I'll post a link when I'm not on my phone
95yj- Grim-
Overhead is offline
post #118 of 253 Old 03-15-2014, 09:37 PM Thread Starter
Overhead
my shocks we're limiting my travel on my RC lift, so I wanted to make sure the BDS had enough room to do there thing. I did my research on here similar to this thread, you can find my info here http://www.jeepforum.com/forum/f12/s...tions-2171953/
the hoops are here http://www.wfoconcepts.com/pr/13-Tal...9502/3458/3713
yes, that price is correct and freaking awesome.
on the rear, I've got the MORE extensions and I'm relocating my lowers due to a broken mount too. I don't have part numbers or flex numbers because the jeeps still getting tuned in and worked on. I'll have numbers monday/tuesday when I order everything. It's going to be on the road by friday, and at Rausch creek Saturday. What better way to do a shake down then Blacks and reds?
95yj- Grim-
Overhead is offline
post #119 of 253 Old 03-15-2014, 09:38 PM Thread Starter
Overhead
I'd like to say thank you to everyone providing input and guidance in this thread.
95yj- Grim-
Overhead is offline
post #120 of 253 Old 03-15-2014, 09:41 PM
panaceabeachbum
thanks ordered the hoops, I assume 5100 series on the shocks?
Some how I missed the shock thread
