Rough Country 4" lift - JeepForum.com
post #1 of 22 Old 11-18-2005, 08:26 PM Thread Starter
headkase
Just ordered one, it will be here next. Due to the holidays I wont be in town so maybe I will get it installed the first week of december.....I can't wait!!!
headkase is offline
post #2 of 22 Old 11-18-2005, 08:33 PM
oct7brian
oct7brian's Avatar
I have one and am very happy had it almost a year now and it has performed well off and on road. Hope you like it
1998 Grand Cherokee 5.9 Limited Edition, Upcountry Suspension for Now, Infinity Sound, NP 242 Swap
2002 Jeep Liberty Sport 4x4 3.7L Auto
1998 TJ 4.0 Auto Sahara Package 4" Suspension Lift 33 BFG Hard & Soft Top
oct7brian is offline
post #3 of 22 Old 11-18-2005, 08:39 PM
xeon
Good luck with it! Make sure you retorque everythign after 500 miles!
Also those RC springs are goign to be very stiff when you first get them. They should soften up after use, or put a couple sand bags in the back .
88YJ, 350TBI, 700R4, Atlas 4.3, HP60, 14B (At a mall near you)
Tri-State (NJ-NY-PA) 4x4 Wheeling Group
xeon is offline
post #4 of 22 Old 11-19-2005, 05:07 PM Thread Starter
headkase
They can't be any worse than my stock ones right now. I think they almost sagged completely to the bump stops
headkase is offline
post #5 of 22 Old 11-19-2005, 07:32 PM
Jeepersusa.4t.c
I put the same lift on my YJ and I fit 33's no problem, and it looks great , the only thing is a little rubbing on the front leafs a rim wit some more backspacing or a wheel spacer will help. Good luck
Marco
____________________________
80 CJ 7 Stock
90 YJ 4inc lift, 33's warn skid plates, and lots of dreams.
04 KJ daily truck
Jeepersusa.4t.c is offline
post #6 of 22 Old 11-19-2005, 08:23 PM
oct7brian
oct7brian's Avatar
Here's what my RC lift looks like but I'm also running a 1.5" Shackle Lift and 2" Body Lift. I am also running 33's I've been told to put 35" on but I have little to no rub with the way I have it now
post #7 of 22 Old 11-19-2005, 08:44 PM
crazymon01
crazymon01's Avatar
i have the same kit.. i love it but make sure u have ur factory bump stops and the bump stops that come with it on if u go off roadin... i just bent a spring couple weeks ago when i went because my factory stop rotted off and i put a negative arch in the spring. have fun
4.0
I6
ARB snorkle
307 -> 411 gear swap
lock rite locker on the dana 35
33 x 12.50 Mickey Thompson radial MTZ
4.5" Rubicon Express heavy duty Suspension Lift
currie boomerang shackles
8,000 lbs. Winch
bikini top
tonneau cover
pictures??
crazymon01 is offline
post #8 of 22 Old 11-20-2005, 09:23 AM Thread Starter
headkase
What gears are you running? I have the 3.07's and Im worried about going bigger than 32's without regearing.
1992 YJ I6 5sp
4" RC lift / 33x12.50 MTR's / Custom front bumper with grille guard/light bar and rear bumper with tire carrier/ 8.8 rear, dana 30 front--4.10's / 1" custom lift shackles
headkase is offline
post #9 of 22 Old 11-20-2005, 09:53 AM
Sugarfuzz
I'm not so sure if you posted in the right thread or not but: You can run 3.07s with 32 or 33s but its no fun I guess it depends on how much you wheel your Jeep and if its a daily driver or not.
2000 Jeep Wrangler 4.0 | 4" Superlift, 33x12.50 BFG Mud Terrains, 4WDHW Rear Bumper
OTHER RIDES:
1993 Mazda RX7(HBP, T04R), 1999 Honda Civic Si(AutoX/DD Car), 1975 & 1977 Honda GL1000
Sugarfuzz is offline
post #10 of 22 Old 11-20-2005, 01:05 PM Thread Starter
headkase
Well, since the author of the thread was.......me, AND it had to do with the topic I posted, then I believe its in the right place.
1992 YJ I6 5sp
headkase is offline
post #11 of 22 Old 11-20-2005, 02:59 PM
95 jeeper
I just got done putting 33's on mine with 307's and a I6 and it's driveable but I definatly need to go to at least 410's. There is no power with it with the 307's
95 jeeper is offline
post #12 of 22 Old 11-20-2005, 06:22 PM Thread Starter
headkase
cool thanks. Im trying to get the money and the parts together to make the switch to 4.10's. Why in the hell, in DC infinite f*cking wisdom, did they make a gearset that required a different carrier than every other gearset in the lineup? It just doesnt make sense. So, now instead of just changing gears out, I have to change carriers too. I guess its a good time to go to limited slip.... Good thing I will be doing it myself, or else I couldnt afford to feed my family
1992 YJ I6 5sp
headkase is offline
post #13 of 22 Old 11-21-2005, 08:50 AM
Sugarfuzz
Yeah I missed that. Ignore me.
Did you ever think of getting a Ford 8.8 or a D44 even? You could find the 8.8 in a junkyard with 4.10 for a reasonable price (well, hopefully).
OTHER RIDES:
post #14 of 22 Old 11-21-2005, 03:35 PM Thread Starter
headkase
I just found that out today, about the ford rearend. What all goes into the swap? I'm sure I could search but im lazy..
And is there a certain year range?
1992 YJ I6 5sp
headkase is offline
post #15 of 22 Old 11-21-2005, 03:42 PM
tobias94yj
Hillbilly Member
tobias94yj's Avatar
Don't be lazy just search it is a very cool tool here
To view the NEW
click here!!!
tobias94yj is offline
Rough country 4" lift kit? bulrokyj YJ Wrangler Technical Forum 27 01-02-2013 06:24 PM
Rough Country 4" Lift vs. Tuff Country 4" Lift reecep14 TJ Wrangler Technical Forum 3 07-29-2010 02:25 PM
Rough Country 3.25" Lift rusty-rubi TJ Wrangler Technical Forum 4 07-30-2009 06:46 PM
Rough Country or Tuff Country 2.5" Lift? bballard1227 YJ Wrangler Technical Forum 7 09-23-2008 06:55 PM
2" Rough Country lift kit khunter2 YJ Wrangler Technical Forum 4 02-08-2007 06:14 PM
